跳至主要内容
Advantech EdgeHub Suite for Windows Release Notes
July 19, 2024
Please read this document carefully. It includes late-breaking information about Advantech EdgeHub Suite for Windows.
Version Information​
[Download the latest release from GitHub](https://github.com/Advantech-IIoT/edgehub-suite/releases)
### V1.4.7 (2024/07/19)
* Upgrade Advantech EdgeHub Device Agent to 1.5.8
- Add mass deployment (bootstrap server) support
- Add API: PUT /edgehub/api/bootstrap/config
- Replace "localhost" with "127.0.0.1"
- Register service by mDNS with name: "_edgehub._tcp.local"
- Mass deployment bootstrap client skip self-signed certificate automatically
- Set QoS to 1 to support iothub GWV2
* Upgrade Advantech Platform Portal Service to 1.4.0 (web portal version 1.4.0)
- Add mess deployment (bootstrap setting) UI
- Add remote desktop UI
- Try to create the device in "LOGIN TO EDGEHUB"
- Get the EdgeHub station list online
* Upgrade Platform REST API Service to 1.3.3
- Add remote desktop support
- Add API: POST /platform/api/rdesk/config
- Add WebSocket API: GET wss://[host:port]/platform/api/rdesk/:id
- The Windows installer will install Winvnc 1.4.3.6 by default
### V1.3.4 (2023/10/27)
* Upgrade Advantech Authentication Service to 1.11.0
- Update auth-server HTTPS port to 56443 to prevent conflicts with the Kubernetes API server
- Upgrade Advantech EdgeHub Device Agent to 1.4.1
- Add a protection mechanism to prevent multiple service instances from running simultaneously and improve overall stability.
- Support detection of revoked certificates, enhancing security by promptly identifying potentially compromised connections.
- Support real-time status updates of connection storms.
- Support X.509 certificates to enhance security and authentication capabilities for secure communications.
- Rename Edge365 to EdgeHub
* Upgrade Advantech Platform Portal Service to 1.2.0 (web portal version 1.2.2)
- Update UI/UX to provide a more intuitive and visually appealing interaction.
* Add a full project to build an installer, including the WISE-Agent V1.4.45
### V1.1.6 (2023/07/07)
* Upgrade Advantech Edge365 Device Agent from 1.0.5 to 1.0.7
- Upgrade MQTT broker to 2.2.12
- Fixed the agent crash issue if the WISE-Agent was not installed
- Complete the shutdown process when the AppHub and Wise-Agent services are force-stopped and disconnected (connection lost)
* Add a compact project to build an installer without including the AppHub
### V1.1.4 (2023/05/26)
* Upgrade Advantech Edge365 Device Agent to 1.0.5
- Add AppHub config file manager
- Add DeviceOn config file manager
- Add Edge Bus service (Embedded MQTT Broker)
- IoTHub MQTT using the host's CA set by default
- Get AppHub location from registry instead of %PATH%
- Update MQTT broker to 2.2.11
- Fix Edge365 widget LED function detection error
- Fix the issue of AppHub cannot reconnect to cloud MQTT when the EdgeBus is turned off
- Fix the typo bug of the command line (service uninstall usage)
* Upgrade Advantech Platform Portal Service to 1.0.1 (web portal version 1.0.3)
- Add functions of Services, Terminal, Display On/Off, and Edge365 Setting UI
* Upgrade Platform REST API Service to 1.0.3
- Add OS Service APIs
- Add Web Terminal APIs
- Add Display On/Off APIs
- Add Linux LED support
- Fix GPIO-related APIs panic issue
* Upgrade Authentication Service from to 1.9.1
* Upgrade Advantech EdgeX Helper to 1.0.1
### V1.0.9 (2023/04/27)
* Upgrade Advantech Edge365 Device Agent from 0.17.1 to 1.19.1
- Disable DeviceOn iBMCPlugin by default
- Refine AppHub config file management
- Upgrade the MQTT library to 1.4.2
- Fixed goroutine leak issue
- Disable the AppHub log file and set the log level to “error” by default to manipulate the config file directly
- Convert tags of model name to the profile
* Upgrade Advantech Platform Portal Service from 0.18.1 to 0.18.2 (web portal version 0.17.2)
- Get rid of the BI station
- Redirect to the current route after re-login
- Add desktop shortcut
* Upgrade Platform REST API Service from 0.19.1 to 0.21.1
- BIOS version from EAPI/SUSI API, version from SMBIOS Type 0 only if there is no EAPI/SUSI API
- Use windows.NewLazySystemDLL to prevent DLL hijacking
- To minimize the lock scope and refine resource protection to avoid race condition
- Support lock screen screenshot
- Support NVRAM disk direct access mode
- Call EApiLibInitialize once to avoid the crash and check the EAPI function pointer before calling to avoid panic
* Upgrade AppHub-Edge from 1.0.12 to 1.1.6
- Add option to enable/disable log file
- Add option to set up log level to display as an error or info
### V1.0.7 (2022/12/23)
* Support remote shutdown and restart of the target device.
* Support AppHub-Edge Windows version
* Add a Dashboard webpage that summarizes system information and a WISE-Edge365 widget.
* Add a Disk webpage that provides an overview of disks, including model name, size, partition list, usage, and S.M.A.R.T. information(if available).
* Add a Process Monitor webpage that provides information about running processes and could search or kill these processes.
* Add a Networking webpage that allows users to monitor network adapters.
* Add a Trap Receiver webpage that receives the SNMP Traps and the Variable Bindings.
* Add EdgeX webpage that serves between physical sensing and actuating "things" and our information technology (IT) systems.
* Add Settings webpage that supports DeviceOn/BI and WISE-Edge365 Connection.
## Software Package List
* Advantech EdgeHub Suite 1.4.7
* Advantech Authentication Service 1.11.0
* Advantech EdgeHub Device Agent 1.5.8
* Advantech Platform Portal Service 1.4.0 / web portal-potal 1.4.0
* Advantech Platform REST API Service 1.3.3
* AppHub-Edge 1.1.6 (Windows)
* Advantech EdgeHub Suite Compact 1.4.7 (* without AppHub)
* Advantech EdgeHub Suite Full 1.4.7 (* including Wise-Agent)
* Wise-Agent 1.4.45 (Windows only)
## Software Prerequisite
* AdvLmsensor V1.06.001 or later.
* AdvSNMPSubagent V2.0.000 or later (Option)
* AdvWDT V3.10.002 or later.
* Docker Desktop V4.13.1 or later. (Option, for EdgeX)
* PlatFormSDK V1.6.4 or later.
## OS support list
* Windows 10 1809(OS Build 17763)
* Windows 10 21H2(OS Build 19044)
* Windows 11 21H2(OS Build 22000)
* Windows 11 24H2(OS Build 26100)
## HW Validation list
* UNO-137-E1
* UNO-137_V2
* UNO-148
* UNO-2372G-J121AE
* UNO-2372G_V2
* UNO-238_V2
* UNO-2473G
* UNO-2484G-653xAE
* UNO-2484G_V2
* TPC-300-R87xA
* TPC-B520
* PPC-6151C-7760
## Notes
* Installation Steps
* Run **Advantech EdgeHub Suite_x.y.z.exe** as administrator to install all packages.
After the installation is complete, you will find packages in these folders:
* Advantech Authentication Service: C:\Program Files\Advantech\auth-server
* Advantech EdgeHub Device Agent Service: C:\Program Files\Advantech\edgehub-agent
* Advantech Platform Portal Service: C:\Program Files\Advantech\portal-service
* Advantech Platform REST API Service: C:\Program Files\Advantech\rest-server
## Important Features
Advantech Platform Portal is a device management and debugging tool that lets you configure and manage device settings and view diagnostic information over HTTP from a web browser.
* Web Browser Support
Suggest using Google Chrome in the desktop version. (Internet Explorer is not supported)
* Login password & setting
Login Advantech Platform Portal with the following:
* OS Account
* Admin Account (must change the password on the first login)
Username: **admin**
Password: **p@ssw0rd**
Advantech Platform Portal, login time session is limited to 15 mins. During this period user has modification right.
* Certificate
Under the same domain, the client can connect to the server through a web browser using HostName. URL: "`https://{IP address of the desktop}:17443"`
* EdgeHub
Support enabling and disabling the connection to the EdgeHub station.
* REST API
All Platform Portal functionality is built on REST APIs that developers can call directly to access resources and control their devices programmatically.
## Checksum Information
Filename | MD5 | CRC32 | SHA-256 | File Size |
Advantech EdgeHub Suite_1.4.7.exe|2e22e4bd88c55dce1b293915603f01ae|b374463a|300bf26712d2801c2bfa9cad2e6d761a93d11fb0ad06c9dd2ed96697fea5b8ff|74,755,896 |
Advantech EdgeHub Suite Compact_1.4.7.exe|c726312919a718528de798acc15562c7|eb8c349a|2051504c8c16c7fa231667b78dfd4193baed4dfd58eb88eed6bac8f2cd4bd633|31,404,096|
Advantech EdgeHub Suite Full_1.4.7.exe|fb02599f53808c62c7a62184a2d4a281|ec4cd02a|adfd93caf2b6a47de03217e5b52f22792fd9d953929e11943e90fe04408915c1|188,876,440|
# Advantech EdgeHub Suite for Linux Release Notes
July 19, 2024
Please read this document carefully. It includes late-breaking information about Advantech EdgeHub Suite for Linux.
## Version Information
* Add mass deployment (bootstrap server) support
* Add API: PUT /edgehub/api/bootstrap/config
* Replace "localhost" with "127.0.0.1"
* Register service by mDNS with name: "_edgehub._tcp.local"
* Mass deployment bootstrap client skip self-signed certificate automatically
* Set QoS to 1 to support iothub GWV2
* Add mess deployment (bootstrap setting) UI
* Add remote desktop UI
* Try to create the device in "LOGIN TO EDGEHUB"
* Get the EdgeHub station list online
* Add remote desktop support
* Add API: POST /platform/api/rdesk/config
* Add WebSocket API: GET wss://[host:port]/platform/api/rdesk/:id
* The Linux installer will try to install the VNC server by the system package manager
* Add AppHub config file manager
* Add DeviceOn config file manager
* Add Edge Bus service (Embedded MQTT Broker)
* IoTHub MQTT using the host's CA set by default
* Get AppHub location from registry instead of %PATH%
* Update MQTT broker to 2.2.11
* Fix Edge365 widget LED function detection error
* Fix the typo bug of the command line. (service uninstall usage)
* Fix the issue of AppHub cannot reconnect to cloud MQTT when the EdgeBus is turned off
* Add OS Service APIs
* Add Web Terminal APIs
* Add Display On/Off APIs
* Add Linux LED support
* Fix GPIO-related APIs panic issue
* Add functions of Services, Terminal, Display On/Off, and Edge365 Setting UI
* Upgrade Authentication Service to 1.9.1
### V1.0.9 (2023/04/28)
* Upgrade Advantech Edge365 Device Agent from 0.17.1 to 0.19.1
* Convert tags of model name to the profile
* Disable the AppHub log file and set the log level to “error” by default to manipulate the config file directly
* Disable the deviceon iBMCPlugin by default
* Fixed goroutine leak (client->reconnect)
* Refine AppHub config file management
* Upgrade MQTT library to 1.4.2
* Upgrade Advantech Platform REST API Service from 0.19.1 to 0.21.1
* Call EApiLibInitialize once to avoid the crash, and check the EAPI function pointer before calling to avoid panic.
* To minimize the lock scope and refine resource protection to avoid race condition
* Upgrade Advantech Platform Portal Service from 0.14.1 to 0.17.2
* Get rid of the BI station.
* Redirect to the current route after re-login.
* Upgrade AppHub-Edge from 1.0.12 to 1.1.3
* Add option to enable/disable log file.
* Add option to set up log level to display as error or information.
* Support running on amd64, arm64 and armhf platforms.
* Support AppHub-Edge Linux version.
* Support WatchDog function.
* Advantech Platform Portal Service 1.4.0 (Portal: 1.4.0)
* AppHub-Edge 1.1.3 (Linux)
* Advantech EdgeHub Suite Compact 1.4.7 (without AppHub)
* Advantech EdgeHub Device Agent 1.5.6
## OS support list
* amd64
AdvLinuxTU_x64_V3.4.1
AdvLinuxTU-IOTG_V4.0.4
* arm64
AdvRaspbian_V1.0.2_arm64
* armhf
wise710a1-ubuntu1804-v2.0.6
wise710a1-2g-ubuntu1804-v2.0.6
* amd64
UNO-137-E1
UNO-148
UNO-348
UNO-2372G-J121AE
UNO-2484G-653xAE
UNO-2484G-673xAE
UNO-2484G_V2
* arm64
UNO-220
* armhf
WISE-710
## Notes
1. Untar edgehub-suite_x.x.x_linux-[amd64|arm64|armhf].tar.gz
`tar zxvf edgehub-suite_x.x.x_linux-[amd64|arm64|armhf].tar.gz`
2. Apply executable permissions to **install.sh** and run **install.sh** as root privilege to install all packages.
```shell
cd edgehub-suite_x.x.x_linux-[amd64|arm64|armhf]
sudo chmod +x install.sh sudo ./install.sh
After the install is done, you will find the packages are these folders:
* Advantech Authentication Service: /opt/auth-server
* Advantech EdgeHub Device Agent Service: /opt/edgehub-agent
* Advantech Platform Portal Service: /opt/portal-service
* Advantech Platform REST API Service: /opt/rest-server
* The following functions are not supported on the **Advantech Platform Portal** of the Linux version.
* System Devices
* Networking - StaticIP Setting
* Networking - WiFi
* Networking - Routing
* Application Monitor
* OS Account
Username: **admin**
* Certificate
* EdgeHub
* REST API
## Known Issues
* GPIO
#30327 The device with EC driver will be popping the error message "GPIOGetDirection/GPIOGetLevel: This function or ID is not supported at the actual hardware environment".
#32477 The GPIO function does not suppot UNO-2484G_V2/UNO-1372G-E3AE and it will be fixed at next AdvLinuxTU image.
* Hardware Monitor
#30362 The temperature value of WISE-710 is wrong on Platform Portal and it will be retrieved at next release.
* LED
#32873 The LED function does not support and it will be fixed at next AdvLinuxTU image.
* System
#32414 The model name is not displayed correctly on Platform Portal.
#30649 After Install edgehub-suite, the WISE-710 device will reboot repeatedly and it will be retrieved at next release.
* WatchDog
#30368 After enabling WDT on Platform Portal, the device WISE-710 will be popping the error message "failed to enable WDT inappropriate ioctl for device" and it will be retrieved at next release.
#30576 After setting WDT timeout value on Platform Portal, the device UNO-220 will be popping the error message "ffailed to update WDT timeout: invalid argument" because UNO-220 does not support set timeout function.
edgehub-suite_1.4.7_linux-amd64.tar.gz|24765439823c2dd6040ce7193aa120dd|b4faa234|12bd32164b818632cb5bce062047174a9f4b73f52e4643a69d7c50c1acd04aac|92,296,935|
edgehub-suite_1.4.7_linux-arm64.tar.gz|b87f4b28e3caf2b984535a0f7c98852f|17e49012|f7c00e6e2fd978ea9bb3cb83be7bf6528520672b346e86b4f8737de00053a10a|89,910,894|
edgehub-suite_1.4.7_linux-armhf.tar.gz|e73f4ef8486ebcb21ba70951b9cb4dab|8fd05167|d073c2e23aae656e490cc715535b3de4dc4dec14076720ab01b8df8ae3a10b9e|90,831,184|
edgehub-suite-compact_1.4.7_linux-amd64.tar.gz|8471f1377e285e0d3f9f19ee96866681|d0b0e78a|ebef64ed61c2d5d81bed8bb05677a1044eabc4a433d1193c59c8b9152fc85ca5|28,347,325|
edgehub-suite-compact_1.4.7_linux-arm64.tar.gz|a16216f17939e7d94a0600893e27687e|622794ca|d9fe8eb1c4b1bf91887f7097cca15e73a078b2f4dab13ebe652692a831e78096|25,962,846|
edgehub-suite-compact_1.4.7_linux-armhf.tar.gz|90fb99d99cc8ce6820b26f7610c915bc|db2e3be1|
On this page ...
Is this helpful?
