跳至主要内容
REST APIs
All Platform Portal functionality is built on REST APIs that developers can call directly to access resources and control their devices programmatically.
Authentication
GET /auth/ping​
Ping the server to see if it is still alive.
  • Response 200 OK
    • Body
      pong
GET /auth/agentinfo​
Get the agent information. (since v1.8.1)
  • Response 200 OK
    Request Successfully
    • Body
      "version": "v1.8.1"
GET /auth/version​
Get the API version. (since v1.7.1)
  • Response 200 OK
    • Body
      "version":1.2
GET /auth/token{?m}​
Get with the OS or the admin account and return the JWT token if the user is valid. A request contains a header field in the form of Authorization: Basic , where credentials are the Base64 encoding of username and password joined by a single colon : username:password => (base64) => dXNlcm5hbWU6cGFzc3dvcmQ=
(since v1.7.1, API version 1.1)
  • URI Parameters
    m number (optional) - User account type. (since v1.8.1, API version 1.2)
    • 0: OS account (default)
    • 2: admin account (default password: p@ssw0rd, must be changed after login)
  • Request Header
  • Response 200 OK
    Login Successfully
    • Body
      "code": 200
      "expire":"20XX-XX-XXT14:08:33+08:00"
      "token": ""
    • Cookie (if available)
      Secure and HttpOnly cookies
      Key: jwt
      Value:
  • Response 401 Unauthorized
    Login Failed
    "Code": 401,
    "Message": ""
POST /auth/login{?m}​
Log in with the OS or admin account and return the JWT token if the user is valid.
  • URI Parameters
    m number (optional) - User account type. (since 1.8.1, API version 1.2)
  • Request body
    "username": "your_username",
    "password": "your_password"
  • Response 200 OK
    Login Successfully
    • Body
      "code": 200
      "token": ""
      Key: jwt
      Value:
    Login Failed
    "Code": 401,
    "Message": ""
POST /auth/logout​
Log out and clear the cookie.
  • Response 200 OK
    "code": 200
GET /auth/certificate​
Download the JWT certificate file in the PEM format.
  • Response 200 OK
    Headers
    Content-Type: application/octet-stream
    Content-Description: File Transfer
    Content-Transfer-Encoding: Binary
    Content-Disposition: attachment; filename=cert.pem.crt
PUT /auth/user/admin/password​
Change the admin’s password. (since 1.8.1, API version 1.2)
  • Request Headers
    Log in with the admin account to get the JWT token (token field from the response body).
    Authorization: Bearer
  • Request Body
    "old": "",
    "new": "",
  • Response 200 OK
  • Response 400 Bad Request
    "code": 400, // optional
    "message": ""
    "code": 401,
    "message": ""
  • Response 422 Unprocessable Entity
    The request has been applied, but the request body is invalid.
    "errors": {
    "validator": ""
DELETE /auth/user/admin/password​
Reset the admin’s password to the default value (p@ssw0rd). (since 1.8.1, API version 1.2)
  • Request Headers
  • Response 200 OK
    "message": ""
    "code": 401,
    "message": ""
H/W Monitor
GET /platform/api/hwmon​
Get all H/W Monitor data, including Temperature, Voltage, Current, and Fan Speed.
  • Request Headers
    Log in with your OS account or the admin account to get the JWT token (token field from the response body).
  • Response 200 OK
    "temperature": [
    "name": "CPU",
    "value": "50.1",
    "unit": "Celsius"
    "voltage": [
    "name": "VCore",
    "value": "0.92",
    "unit": "Volt"
    "name": "12V",
    "value": "11.86",
    "unit": "Volt"
    "current": [
    "name": "OEM0",
    "value": "0.54",
    "unit": "A"
    "fanspeed": [
    "name": "FAN0",
    "value": "1234",
    "unit": "RPM"
    "Code": 401,
    "Message": ""
  • Response 404
    Not supported or no available data.
GET /platform/api/hwmon (SSE)​
Get all H/W Monitor data, including Temperature, Voltage, Current, and Fan Speed via Server-Sent Events (SSE).
  • EventStream
    event: message
    data: {"current":[{"name":"OEM0","value":0.34, "unit":"A"}],"temperature":[{"name":"CPU","value":41, "unit":"Celsius"}],"voltage":[{"name":"Vcore", "value":0.92,"unit":"Volt"},{"name":"12V","value":11. 86,"unit":"Volt"},{"name":"5V Standby","value":4.95, "unit":"Volt"},{"name":"CMOS Battery","value":3.05, "unit":"Volt"}]}
GET /platform/api/hwmon/temperatures​
Get H/W Monitor temperature data.
  • Request Headers
  • Response 200 OK
    ```json
[ { "name": "CPU", "value": 40, "unit": "Celsius" }, ... ]
    "Code": 401,
    "Message": ""
  • Response 404
GET /platform/api/hwmon/voltages​
Get H/W Monitor voltage data.
  • Request Headers
  • Response 200 OK
    ```json
[ { "name": "Vcore", "value": 0.92, "unit": "Volt" }, ... ]
    "Code": 401,
    "Message": ""
  • Response 404
GET /platform/api/hwmon/currents​
Get H/W Monitor current data.
  • Request Headers
  • Response 200 OK
    ```json
[ { "name": "OEM0", "value": 0.54, "unit": "A" }, ... ]
    "Code": 401,
    "Message": ""
  • Response 404 Not Found
GET /platform/api/hwmon/fanspeeds​
Get H/W Monitor fan speed data.
  • Request Headers
  • Response 200 OK
    ```json
[ { "name": "FAN0", "value": 1234, "unit": "RPM" }, ... ]
    "Code": 401,
    "Message": ""
Platform
GET /platform/api/ping​
  • Response 200 OK
    • Body
      pong
GET /platform/api/agentinfo​
Get the agent information. (since v0.14.1)
  • Response 200 OK
    • Body
      "version": "v0.14.1"
Portal
GET /api/ping​
Ping the portal-service server to see if it is still alive.
  • Response 200 OK
    • Body
      pong
GET /api/agentinfo​
Get the portal-service agent information. (since v0.14.1)
  • Response 200 OK
    • Body
GET /api/irtm/ping​
Ping the iFactory RTM server to see if it is still alive.
  • Response 200 OK
    • Body
      pong
System Information
Host Information​
GET /platform/api/host/info​
Get host information, including BIOS information, Boot Count, Boot Time, Device Name (BIOS Name), OS Information, and Image Information (if available).
  • Request Headers
  • Response 200 OK
    "biosSerialNumber": "Default string",
    "biosUUID": "03000200-0400-0500-0006-000700080009",
    "biosVersion": "N/A",
    "bootCount": 22862,
    "bootTime": 1619413851,
    "deviceName": "UNO-2484G-673xAE",
    "dockerVersion": "Docker version 19.03.13, build 4484c46d9d",
    "ecVersion": "0.5",
    "hostid": "d6d6752c-a6d4-4d02-96b1-96e2d3a8d2b2",
    "hostname": "UNO-2484G-673xA",
    "imageVersion": "6.04 Build 005",
    "kernelArch": "x86_64",
    "os": "windows",
    "platform": "Microsoft Windows 10 Enterprise LTSC 2019",
    "releaseDate": "01/23/2019",
    "upTime": 851779
    "Code": 401,
    "Message": ""
GET /platform/api/host/display/count​
Get available display count.
  • Prerequisite
    • rest-server 0.12.1.0 and later
  • Request Headers
  • Response 200 OK
    1
    "Code": 401,
    "Message": ""
GET /platform/api/host/screenshot/:index​
Get the specified display screenshot by index
  • Prerequisite
  • Request Headers
  • Response 200 OK
    "data": "",
    "mediaType": "image/png"
    You can use Data URLs to render the response base64 encoded image.
    data:[][;base64],
    "Code": 401,
    "Message": ""
    The request has been applied but got errors.
    "errors": {
    "Host": ""
GET /platform/api/host/screenshot/:index/file​
Get the specified display screenshot file by index
  • Prerequisite
  • Request Headers
  • Response 200 OK
    Returns the screenshot image file directly
    "Code": 401,
    "Message": ""
    "errors": {
    "Host": ""
System Performance​
GET /platform/api/systemperf​
Get CPU, Memory information, and usage.
  • Request Headers
  • Response 200 OK
    "cpu": {
    "info": {
    "cpu": 0,
    "vendorId": "GenuineIntel",
    "family": "6",
    "model": "78",
    "stepping": 3,
    "physicalId": "0",
    "coreId": "0",
    "cores": 1,
    "modelName": "Intel(R) Core(TM) i7-6600U CPU @ 2.60GHz",
    "mhz": 2600,
    "cacheSize": 4096,
    "flags": [
    "sse",
    "sse2",
    "microcode": "0xc6"
    "usage": [
    0,
    0,
    0.9999999999990905,
    0
    "memory": {
    "total": 8265986048,
    "available": 7532920832,
    "used": 415899648,
    "usedPercent": 5.031458383608441,
    "free": 6488629248,
    "Code": 401,
    "Message": ""
GET /platform/api/systemperf/cpu​
Get CPU information and usage.
  • Request Headers
  • Response 200 OK
    "info": {
    "cpu": 0,
    "family": "6",
    "model": "78",
    "stepping": 3,
    "physicalId": "0",
    "coreId": "0",
    "cores": 1,
    "mhz": 2600,
    "cacheSize": 4096,
    "flags": [
    "sse",
    "sse2",
    "microcode": "0xc6"
    "usage": [
    1.5625,
    0,
    1.5625,
    0
    "Code": 401,
    "Message": ""
GET /platform/api/systemperf/memory​
Get memory information and usage.
  • Request Headers
  • Response 200 OK
    "available": 7532576768,
    "used": 417800192,
    "usedPercent": 5.05445072824783,
    "free": 6486446080,
    "Code": 401,
    "Message": ""
System Devices
GET /platform/api/devmgr​
Get a list of the hardware attached to the computer.
  • Request Headers
  • Response 200 OK
    ```json
[ { "class": "ACPI", "instancePath": "ACPI\PNP0000\4&15FBC11C&0", "name": "Programmable interrupt controller", "status": "stopped" }, { "class": "STORAGE", "instancePath": "STORAGE\VOLUME\{7963B29A-147B-11EB-92A9-806E6F6E6963}#000000002F900000", "name": "Volume", "status": "running" }, { "class": "STORAGE", "instancePath": "STORAGE\VOLUME\{7963B29A-147B-11EB-92A9-806E6F6E6963}#000000001F500000", "name": "Volume", "status": "running" }, { "class": "PCI", "instancePath": "PCI\VEN_8086&DEV_9D15&SUBSYS_72708086&REV_F1\3&11583659&0&E0", "name": "PCI-to-PCI Bridge", "vendorID": "8086", "deviceID": "9D15", "status": "running" }, { "class": "USB", "instancePath": "USB\VID_05E3&PID_0612\5&2C705BFE&0&15", "name": "Generic SuperSpeed USB Hub", "vendorID": "05E3", "deviceID": "0612", "status": "running" } ]
    "Code": 401,
    "Message": ""
    "errors": {
    "DevMgr": ""
Service
(since rest-server 1.0.1)
GET /platform/api/service/list​
Get the service list
  • Request Headers
  • Response 200 OK
    ```json
[ { "name": "AppHubEdgeService", "displayName": "AppHub-Edge Service", "description": "", "status": "running" }, { "name": "ALG", "displayName": "Application Layer Gateway Service", "description": "Provides support for 3rd party protocol plug-ins for Internet Connection Sharing", "status": "stopped" }, .. ]
    "Code": 401,
    "Message": ""
    "errors": {
    "Service": ""
GET /platform/api/service/:name​
Get the service status by name.
  • Request Headers
  • Response 200 OK
    The available status will be "running", "stopped", "disabled", or "unknown".
    "status": "running"
    "Code": 401,
    "Message": ""
    "errors": {
    "Service": ""
PUT /platform/api/service/:name​
Control the service status by name.
  • Request Headers
  • Request Body
    "action": "start" | "stop" | "restart"
  • Response 204 No Content
    The requested operation is successful.
    "Code": 401,
    "Message": ""
    "errors": {
    "Service": ""
Terminal
GET /platform/api/term/ws​
Get the web terminal basic information.
  • Request Headers
  • Response 200 OK
    "os": "windows" | "linux",
    "Code": 401,
    "Message": ""
GET wss://(URL)/platform/api/term/ws​
Open a local shell, making it communicate to WebSocket using stdin/stdout.
  • Request Headers
  • Message Description
      • Outbound Message ↑
        CmdDataDescription
        1base64-encoded terminal outputterminal output
        2Pong message (heartbeat)
        3The New TitleSet window title
        4{"font-size":12,"font-family":"serif"}Set Preferences
        5falseSet auto reconnect
        61024Set Buffer Size
      • Inbound Message ↓
        CmdDataDescription
        1base64-encoded terminal inputterminal input data
        2Ping message
        3{"columns":128,"rows":21}Resize Terminal
Peripheral
LED​
GET /platform/api/perif/led​
Get an LED list with high-low values.
  • Request Headers
  • Response 200 OK
    true -> logical high, false -> logical low
    ```json
[ true, false, true, false, true, false, true, true ]
    "Code": 401,
    "Message": ""
GET /platform/api/perif/led/:id​
Get the specified LED value by index (id)
  • Request Headers
  • Response 200 OK
    true | false
    "errors": {
    "LED": ""
    "Code": 401,
    "Message": ""
PUT /platform/api/perif/led/:id​
Set the value of the specified LED by index (id)
  • Request Headers
  • Request Body
    "status": true | false
  • Response 200 OK
    Invalid Parameters Error
    "errors": {
    "LED": ""
    "Code": 401,
    "Message": ""
    The request body has missing parameters.
    "errors": {
    "validator": ""
    "errors": {
    "LED": ""
Watchdog​
GET /platform/api/perif/wdt​
Get hardware watchdog information.
  • Request Headers
  • Response 200 OK
    "enabled": ,
    "type": "EC Watchdog",
    "timeoutInSeconds": 15,
    "timeoutMaxInSeconds": 255,
    "timeoutMinInSeconds": 10
    "Code": 401,
    "Message": ""
    "errors": {
    "WDT": ""
PUT /platform/api/perif/wdt​
Set hardware watchdog enabled or disabled with provided timeout value (optional).
  • Request Headers
  • Request Body
    The seconds value range is [timeoutMinInSeconds, timeoutMaxInSeconds]
    "enabled": , // required
    "seconds": [timeoutMinInSeconds, timeoutMaxInSeconds], // optional
  • Response 200 OK
    "enabled": ,
    "seconds":
    "Code": 401,
    "Message": ""
    "errors": {
    "WDT": ""
PUT /platform/api/perif/wdt/timeout​
Set hardware watchdog timeout value (in seconds).
  • Request Headers
  • Request Body
  • Response 200 OK
    "seconds":
    "Code": 401,
    "Message": ""
    "errors": {
    "WDT": ""
Disk​
GET /platform/api/perif/disk​
Get installed harddisk information, including model name, size, partition list, usage, and S.M.A.R.T. information (if available).
  • Request Headers
  • Response 200 OK
    ```json
[ { "name": "\\.\PHYSICALDRIVE0", "sizeBytes": 64017354240, "physicalBlockSizeBytes": 0, "removable": false, "vendor": "(Standard disk drives)", "model": "SQF-S25M4-64G-S9C", "serialNumber": "XXXXXXXXXXXXX", "firmwareRevision": "XXXXX8", "mediaType": "Fixed hard disk media", "partitions": [ { "mountPoint": "C:", "sizeBytes": 63208157184, "freeBytes": 47287078912, "usedBytes": 15921078272, "usedPercent": 25.188328502685938, "readOnly": false } ], "smartAttributes": [ { "id": 1, "name": "Read Error Rate", "statusFlags": 10, "value": 100, "worst": 100, "threshold": 50, "rawData": [ 0, 0, 0, 0, 0, 0 ]
    "Code": 401,
    "Message": ""
GET /platform/api/perif/disk (SSE)​
Get installed hard disk information via Server-Sent Events (SSE), including model name, size, partition list, usage, and S.M.A.R.T. information (if available).
  • EventStream
    event: message
    data: [{"name":"\\\\.\\PHYSICALDRIVE0","sizeBytes":64017354240,"physicalBlockSizeBytes":0,"removable":false,"vendor":"(Standard disk drives)","model":"SQF-S25M4-64G-S9C","serialNumber":"FF73076C030806395366","firmwareRevision":"S9FMA028","mediaType":"Fixed hard disk media","partitions":[{"mountPoint":"C:","sizeBytes":63208157184,"freeBytes":27825188864,"usedBytes":35382968320,"usedPercent":55.97848425955465,"readOnly":false}],"smartAttributes":[{"id":1,"name":"Read Error Rate","statusFlags":10,"value":100,"worst":100,"threshold":50,"rawData":[0,0,0,0,0,0]},{"id":9,"name":"Power-On Hours (POH)","statusFlags":18,"value":100,"worst":100,"threshold":0,"rawData":[118,38,0,0,0,0]},{"id":12,"name":"Power Cycle Count","statusFlags":18,"value":100,"worst":100,"threshold":0,"rawData":[219,0,0,0,0,0]},{"id":168,"name":"Vendor Specific","statusFlags":18,"value":100,"worst":100,"threshold":0,"rawData":[0,0,0,0,0,0]},{"id":170,"name":"Vendor Specific","statusFlags":3,"value":86,"worst":86,"threshold":10,"rawData":[52,0,0,0,0,0]},{"id":173,"name":"Vendor Specific","statusFlags":18,"value":100,"worst":100,"threshold":0,"rawData":[203,11,158,0,0,0]},{"id":192,"name":"Power-off Retract Count","statusFlags":18,"value":100,"worst":100,"threshold":0,"rawData":[21,0,0,0,0,0]},{"id":194,"name":"Temperature","statusFlags":35,"value":70,"worst":70,"threshold":0,"rawData":[30,0,0,0,0,0]},{"id":218,"name":"Vendor Specific","statusFlags":11,"value":100,"worst":100,"threshold":50,"rawData":[0,0,0,0,0,0]}]}]
GET /platform/api/perif/disk/partition​
Get the partition list of installed disks.
  • Request Headers
  • Response 200 OK
    ```json
[ { "mountPoint": "C:", "sizeBytes": 63208157184, "freeBytes": 27825188864, "usedBytes": 35382968320, "usedPercent": 55.97848425955465, "readOnly": false } ]
    "Code": 401,
    "Message": ""
Redundant Power​
GET /platform/api/perif/redundant_power​
Get redundant power status.
  • Request Headers
  • Response 200 OK
    1: online 0: offline
    "vin1State": 0 | 1,
    "vin2State": 0 | 1
    "Code": 401,
    "Message": ""
GET /platform/api/perif/redundant_power (SSE)​
Get redundant power status via Server-Sent Events (SSE).
  • EventStream
    event: message
    data: {
    "vin1State": 0 | 1,
    "vin2State": 0 | 1
GPIO​
(since rest-server v0.15.1)
GET /platform/api/perif/gpio/count​
Get available GPIO count.
  • Request Headers
  • Response 200 OK
    "count": 8,
    "Code": 401,
    "Message": ""
GET /platform/api/perif/gpio/all​
Get all the available GPIO pins configuration.
  • Request Headers
  • Response 200 OK
    ```json
[ { "pin": 0, // 0-based pin index (:id) "dir": 0, // direction. 0: output, 1: input "level": 0 // level. 0: low, 1: high }, { "pin": 1, "dir": 1, "level": 1 }, ... { "pin": 7, "dir": 1, "level": 1 } ]
    "Code": 401,
    "Message": ""
    "errors": {
    "GPIO": ""
GET /platform/api/perif/gpio/:id​
Get the specified GPIO pin (by index :id) direction and level.
  • Request Headers
  • Response 200 OK
    "dir": 0, // dir. 0: output, 1: input
    "level": 0, // level. 0: low, 1: high
    Invalid parameter (incorrect :id)
    "errors": {
    "GPIO": "invalid parameter"
    "Code": 401,
    "Message": ""
    "errors": {
    "GPIO": ""
GET /platform/api/perif/gpio/:id/dir​
Get the specified GPIO pin (by index :id) direction.
0: output, 1: input
  • Request Headers
  • Response 200 OK
    "errors": {
    "Code": 401,
    "Message": ""
    "errors": {
    "GPIO": ""
PUT /platform/api/perif/gpio/:id/dir​
Set the specified GPIO pin (by index :id) direction.
  • Request Headers
  • Request Body
    0: output, 1: input
    "dir": 0 | 1
  • Response 200 OK
    "errors": {
    "Code": 401,
    "Message": ""
    "errors": {
    "validator": ""
    "errors": {
    "GPIO": ""
GET /platform/api/perif/gpio/:id/level​
Get the specified GPIO pin (by index :id) level.
0: low, 1: high
  • Request Headers
  • Response 200 OK
    "errors": {
    "Code": 401,
    "Message": ""
    "errors": {
    "GPIO": ""
PUT /platform/api/perif/gpio/:id/level​
Set the specified GPO pin (by index :id) level.
  • Request Headers
  • Request Body
    0: low, 1: high
    "level": 0 | 1
  • Response 200 OK
    "errors": {
    "Code": 401,
    "Message": ""
    "errors": {
    "validator": ""
    "errors": {
    "GPIO": ""
Brightness​
(since rest-server v0.16.1)
GET /platform/api/perif/brightness​
Get the brightness information, including brightness minimum, maximum, and value.
  • Request Headers
  • Response 200 OK
    "min": 0, // the supported minimum brightness value
    "max": 9, // the supported maximum brightness value
    "value": 5, // the current brightness value
    "Code": 401,
    "Message": ""
    "errors": {
    "Brightness": ""
PUT /platform/api/perif/brightness​
Set the brightness value.
  • Request Headers
  • Request Body
    "value": 1
  • Response 200 OK
    "Code": 401,
    "Message": ""
    "errors": {
    "Brightness": ""
Networking
GET /platform/api/networking/interfaces​
Get network adapters' information and the current IP configuration.
  • Request Headers
  • Response 200 OK
    Empty if there is no network adapter found.
    ```json
[ { "ifIndex": 2, "uuid": "enp0s31f6", "name": "enp0s31f6", "description": "", "type": "Ethernet", "typeId": 1, "mtu": 1500, "connected": true, "isDefault": false, "hardwareAddress": "xx:xx:xx:xx:xx:xx", "speed": "1 Gbps", "sendSpeed": 1000000000, "recvSpeed": 1000000000, "addresses": [ "172.16.12.91/23", "fe80::6543:2799:56b0:78b/64" ], "gateway": [ "192.168.6.1" ], "dns": [ "192.168.6.1" ], "iocounters": { "ifindex": 2, "bytesSent": 518832090, "bytesRecv": 5103663236, "packetsSent": 593021, "packetsRecv": 58711134, "errin": 0, "errout": 0, "dropin": 0, "dropout": 0, "fifoin": 0, "fifoout": 0 } }, { "ifIndex": 3, "uuid": "enp1s0", "name": "enp1s0", "description": "", "type": "Wi-Fi", "typeId": 71, "mtu": 1500, "connected": false, "isDefault": false, "hardwareAddress": "xx:xx:xx:xx:xx:xx" },
    "Code": 401,
    "Message": ""
GET /platform/api/networking/interfaces (SSE)​
Get network adapters' information and the current IP configuration via Server-Sent Events (SSE).
  • EventStream
    event: message
    data: [{"ifIndex":17,"uuid":"{B30C1205-A9C3-4155-9E01-0AB4D5A36DB4}","name":"Ethernet 4","description":"Intel(R) Ethernet Connection I219-LM","type":"Ethernet","typeId":6,"mtu":1500,"connected":true,"isDefault":false,"dhcpEnabled":true,"hardwareAddress":"74:FE:48:05:0A:EE","sendSpeed":1000000000,"recvSpeed":1000000000,"addresses":["172.16.12.60/23","fe80::4013:3d5e:69a7:460a/64"],"gateway":["172.16.13.254"],"dns":["172.20.1.99","8.8.8.8"],"dnssuffix":"ADVANTECH.CORP","ipv4Metric":1,"ipv6Metric":25,"iocounters":{"ifindex":17,"bytesSent":2721740020,"bytesRecv":6232829747,"packetsSent":4159260,"packetsRecv":3706395,"errin":0,"errout":0,"dropin":0,"dropout":0,"fifoin":0,"fifoout":0}},...]
POST /platform/api/networking/interfaces/route​
Change the sequence of the network interface route (metric).
  • Request Headers
  • Request Body
    The sortedGUIDList is an interface uuid list by order of priority.
    "ipv6": false,
    "sortedGUIDList": [
    "{53E59828-224E-4416-9A05-DE95EB7F4C4A}",
    "{EFCDC03D-30CA-434D-B284-DB517179D7FD}",
    "{D1A142DB-C5F9-40D4-9F1B-A1FE2BE89C33}",
    "{5A0E29AC-4767-4EAB-A2F5-F718F343B198}",
    "{D09F45AC-3A17-4012-B278-45B923978278}",
    "{94CDC116-21A5-4419-90AF-F0626B643566}",
    "{1BB8C682-3B29-47A6-9504-44542CAF918E}"
  • Response 201 Created
    "errors": {
    "networking": ""
    "Code": 401,
    "Message": ""
    "errors": {
    "validator": ""
    The sortedGUIDList is empty or not provided.
    "errors": {
    "networking": "empty list"
PUT /platform/api/networking/ipv4config/:ifIndex​
Sets the IPv4 configuration with static IP and DNS. You can call GET /platform/api/networking/interfaces to get the ifIndex.
  • Request Headers
  • Request Body
"ipAddress": "xxx.xxx.xxx.xxx",
"subnetMask": "xxx.xxx.xxx.xxx",
"defaultGateway": "xxx.xxx.xxx.xxx",
"primaryDNS": "xxx.xxx.xxx.xxx",
"secondaryDNS": null // optional
  • Response 200 OK
"ipAddress": "",
"subnetMask": "",
"defaultGateway": "",
"primaryDNS": "",
"secondaryDNS": ""
    "errors": {
    "validator": ""
    "errors": {
    "Net": ""
DELETE /platform/api/networking/ipv4config/:ifIndex​
Enable DHCP for the specified interface. You can call GET /platform/api/networking/interfaces to get the ifIndex.
  • Request Headers
  • Response 200 OK
    There are missing parameters.
    "errors": {
    "Net": ""
    "errors": {
    "Net": ""
GET /platform/api/networking/wifi/interfaces​
Get Wi-Fi adapters information.
  • Request Headers
  • Response 200 OK
    ```json
[ { "ifIndex": 14, "uuid": "{94CDC116-21A5-4419-90AF-F0626B643566}", "description": "802.11n USB Wireless LAN Card", "profiles": [ { "name": "SQA_2.4G", "allUserProfile": true, "groupPolicyProfile": false, "perUserProfile": false } ]
    "Code": 401,
    "Message": ""
GET /platform/api/networking/wifi/networks/:uuid​
Get a list of all available networks of the specified Wi-Fi adapter selected by uuid.
  • Request Headers
  • Response 200 OK
    Empty if there is no available network found.
    ```json
[ { "alreadyConnected": true, "authenticationAlgorithm": "WPA2-Personal", "channel": 7, "cipherAlgorithm": "AES", "connectable": true, "infrastructureType": "Infrastructure", "profileAvailable": true, "profileName": "SQA_2.4G", "ssid": "SQA_2.4G", "securityEnabled": true, "signalQuality": 100, "signalStrength": -50, "bssid": "E0:3F:49:00:04:30", "physicalTypes": [ "802.11n" ]
"alreadyConnected": false,
"profileAvailable": false,
"profileName": "",
"ssid": "FIVEGGGGGHZ",
"signalQuality": 30,
"signalStrength": -85,
"physicalTypes": [
"802.11ac"
    "Code": 401,
    "Message": ""
    "errors": {
    "WiFi": ""
DELETE /platform/api/networking/wifi/interface/:uuid/profile/:name​
Delete the connected network profile (selected by profile name) of the specified Wi-Fi interface (selected by uuid)
  • Request Headers
  • Response 200 OK
    Profile deleted.
    The profile name is empty.
    "errors": {
    "WiFi": "invalid profile name"
    "Code": 401,
    "Message": ""
    "errors": {
    "WiFi": ""
Process Manager
GET /platform/api/processes​
Get running processes list.
  • Request Headers
  • Response 200 OK
    Empty if there is no running process found.
    ```json
[ { "pid": 1, "name": "systemd", "numThreads": 1, "memUsage": 9187328, "cpuPercent": 0.0010817868420981225, "username": "root", "elapsedTime": 1191547, "path": "/lib/systemd/systemd", "cmdline": "/sbin/init splash" }, { "pid": 2, "name": "kthreadd", "numThreads": 1, "memUsage": 0, "cpuPercent": 0.000013427920447930759, "username": "root", "elapsedTime": 1191547 }, ... ]
    "Code": 401,
    "Message": ""
GET /platform/api/processes (SSE)​
Get running processes list via Server-Sent Events (SSE)
  • EventStream
    event: message
    data: [{"pid":4,"name":"System","numThreads":169,"memUsage":20480,"cpuPercent":6,"username":"NT AUTHORITY\\SYSTEM","elapsedTime":876611},{"pid":56,"ppid":4,"name":"Secure System","memUsage":23273472,"cpuPercent":0,"username":"NT AUTHORITY\\SYSTEM","elapsedTime":876613},{"pid":100,"ppid":4,"name":"Registry","numThreads":4,"memUsage":208896,"cpuPercent":0,"username":"NT AUTHORITY\\SYSTEM","elapsedTime":876612},{"pid":416,"ppid":4,"name":"smss.exe","numThreads":2,"memUsage":98304,"cpuPercent":0,"username":"NT AUTHORITY\\SYSTEM","elapsedTime":876611},{"pid":604,"ppid":572,"name":"csrss.exe","numThreads":12,"memUsage":671744,"cpuPercent":0,"username":"NT AUTHORITY\\SYSTEM","elapsedTime":876609}, ...]
DELETE /platform/api/processes/:pid​
Kill the selected process (selected by pid)
  • Request Headers
  • Response 200 OK
    Profile deleted.
    The :pid is not a valid value.
    "errors": {
    "Processes": "Invalid PID"
    "Code": 401,
    "Message": ""
    "errors": {
    "Processes": ""
Remote Control
POST /platform/api/control/reboot​
Restart the target computer. It requires Admin permission.
  • Request Headers
  • Response 200 OK
    "Code": 401,
    "Message": ""
  • Response 403 Forbidden
    The login user has no permission to reboot the target computer.
    "errors": {
    "Control": ""
POST /platform/api/control/shutdown​
Shut down the target computer. It requires Admin permission.
  • Request Headers
  • Response 200 OK
    "Code": 401,
    "Message": ""
    The login user has no permission to shut down the target computer.
    "errors": {
    "Control": ""
GET /platform/api/control/display​
Check whether the target computer supports the display on/off feature. (since rest-server 1.0.1)
  • Request Headers
    The target computer supports the display on/off feature.
    "Code": 401,
    "Message": ""
    The target computer does not support the display on/off feature.
PUT /platform/api/control/display​
Turn the display of the target computer on or off. (since rest-server 1.0.1)
  • Request Headers
  • Request Body
    "status": "on" | "off"
  • Response 200 OK
    "Code": 401,
    "Message": ""
    "errors": {
    "Control": ""
Remote Desktop
POST /platform/api/rdesk/config​
Gets the remote desktop connection information via WebSocket.
  • Request Headers
    • Include a valid JWT token obtained by logging in with the OS or "admin" account.
  • Response Codes
    • 200 OK (Success)
      • Response body contains:
        • id (string): The unique identifier (UUID) for the remote desktop connection.
        • os (string, optional): Operating system of the remote desktop (e.g., "windows", "linux").
        • password (string): The password for the remote desktop connection.
      "id": "5b306b78-d720-4dac-984e-a1f1ca9cd963",
      "os": "windows",
      "password": "EmzE4lo0"
    • 401 Unauthorized (Authentication failure)
      "Code": 401,
      "Message": ""
    • 422 Unprocessable Entity (Invalid request)
      "message": ""
GET wss://[host:port]/platform/api/rdesk/:id​
Opens a WebSocket connection to communicate with the VNC server for the specified remote desktop.
  • Request Parameters
    • :id (string): The unique identifier (UUID) obtained from the response body of the POST /platform/api/rdesk/config endpoint. This ID identifies the specific remote desktop connection.
  • Request Headers
    The WebSocket connection uses a binary message format to proxy data between the client and the VNC server. The specific format of these messages depends on the VNC protocol version used by the server.
Client-Side Considerations​
  • Utilize the noVNC client-side library (https://github.com/novnc) to establish the WebSocket connection and handle binary VNC message communication.
  • Refer to the noVNC documentation for specific integration and usage instructions.
Events
GET /platform/api/events (SSE)​
Get all available Server-Sent Events (SSE), including the following events (event type).
  • diskdrives
  • hwmon
  • netifaces
  • processes
  • pwrstatus
  • snmptrap
  • systemperf
EventStream​
event:
data:
Example​
  1. Login with your OS account to get the JWT token (token field from the response body).
  2. addEventListener
    const eventSource = new EventSource(`/platform/api/   events?token=`, { withCredentials: true });
    eventSource.addEventListener(, (event) => {
    const data = JSON.parse(event.data);
    // process your data
ETP
GET /platform/api/etp/devicedata​
Get ETP device data.
  • Request Headers
  • Response 200 OK
    "modelName": "XXXXX",
    "serialNumber": "Default string",
    "boardVersion": "Default string",
    "uuid": "00020003-0004-0005-0006-000700080009",
    "version": ""
    "Code": 401,
    "Message": ""
GET /platform/api/etp/userdata​
Get ETP user's data.
  • Request Headers
  • Response 200 OK
    "data": {
    "userSpace1": "",
    "userSpace2": ""
    "locked": true | false
    "errors": {
    "ETP": ""
    "Code": 401,
    "Message": ""
    "errors": {
    "ETP": ""
GET /platform/api/etp/userdata/lockstatus​
Get ETP user data area lockstatus.
  • Request Headers
  • Response 200 OK
    "errors": {
    "ETP": ""
    "Code": 401,
    "Message": ""
    "errors": {
    "ETP": ""
PUT /platform/api/etp/userdata​
Set ETP user's data.
  • Request Headers
  • Request Body
    The maximum length of userSpace1 and userSpace2 is 128 bytes. (RAW data)
    "userSpace1": "",
    "userSpace2": ""
  • Response 200 OK
    "userSpace1": "",
    "userSpace2": ""
    "errors": {
    "ETP": ""
    "Code": 401,
    "Message": ""
    Not supported.
    "errors": {
    "ETP": ""
    "errors": {
    "validator": ""
    The userSpace1 or userSpace2 raw data length is out of range (128 bytes).
    "errors": {
    "ETP": "The maximum length of UserSpace1 is 128"
PUT /platform/api/etp/userdata/lockstatus​
Lock or unlock the ETP user's data area.
  • Request Headers
  • Request Body
    The maximum length of password is 8 byre.
    "locked": true | false,
    "password": ""
  • Response 200 OK
    "locked": true | false, // same as request body
    "errors": {
    "ETP": ""
    "Code": 401,
    "Message": ""
    Not supported.
    "errors": {
    "ETP": ""
    "errors": {
    "validator": ""
    The password length is out of range (1~8 bytes).
    "errors": {
    "ETP": ""
EdgeHub
GET /edgehub/api/ping​
  • Response 200 OK
    • Body
      pong
GET /edgehub/api/agentinfo​
Get the agent information. (since v0.15.1)
  • Response 200 OK
    • Body
      "version":"v0.15.1"
GET /edgehub/api/macaddr​
Get MAC address for device registration.
  • Request Headers
  • Response 200 OK
    "XX:XX:XX:XX:XX:XX"
    "Code": 401,
    "Message": ""
    No available data.
    "message": ""
GET /edgehub/api/connection​
Get connection status.
  • Request Headers
  • Response 200 OK
    "enabled": true | false,
    "status": "connected | disconnected",
    "certRevoked": true | false, // since 1.2.0
    "stormDetected": true | false // since 1.3.1
    certRevoked: indicates whether the certificates are revoked or not
    stormDetected: indicates whether there is a connection storm
    "Code": 401,
    "Message": ""
POST /edgehub/api/connection​
Enable or Disable to the device connection.
  • Request Headers
  • Request Body
    conncfg is optional.
    If the op is "connect" and the conncfg has been provided, it will set the connection setting first, then enable the connection to the cloud; if the conncfg is not provided, it will enable the connection only.
    If the op is "disconnect", it will disable the cloud connection. conncfg will be ignored.
    "op": "connect | disconnect",
    "conncfg": {
    "username": "",
    "password": "",
    "mqttHost": "",
    "mqttPort": 1883,
    "enableTLS": true | false,
    "overWebSocket": true | false,
    "connectionString": "", // optional
    "mac": "AABBCCDDEEFF", // optional,
    "uuid": "123e4567-e89b-12d3-a456-426614174000", // optional
    "deviceon": { // optional (since edgehub-agent 1.0.1)
    "dccsUrl": "",
    "iotKey": ""
    or
    "conncfg": {
    // (since edgehub-agent 1.1.0)
    "deviceTokenCredential": "",
    "skipCertVerify": true | false,
    "dccsUrl": "",
    "iotKey": ""
  • Response 200 OK
    "Code": 401,
    "Message": ""
    No available data.
    "message": ""
GET /edgehub/api/conncfg​
Get the current device connection setting.
  • Request Headers
  • Response 200 OK
    "username": "",
    "password": "",
    "mqttHost": "",
    "mqttPort": 1883,
    "uuid": "123e4567-e89b-12d3-a456-426614174000", // optional,
    "caCerts": ["", ...],
    "iothubKey": "",
    "iothubCert": "",
    "mqttKey": "",
    "mqttCert": ""
    "Code": 401,
    "Message": ""
    No available data.
    "message": ""
POST /edgehub/api/conncfg​
Set the connection setting.
  • Request Headers
  • Request Body
    "username": "",
    "password": "",
    "mqttHost": "",
    "mqttPort": 1883,
    "dccsUrl": "",
    "iotKey": ""
    or
    "dccsUrl": "",
    "iotKey": ""
    "caCerts": ["", ...], // optional
  • Response 200 OK
    "Code": 401,
    "Message": ""
    No available data.
    "message": ""
DELETE /edgehub/api/conncfg​
Clear the current device connection setting.
  • Request Headers
  • Response 200 OK
    "Code": 401,
    "Message": ""
    "message": ""
GET /edgehub/api/profile​
Get the EdgeHub function profile which contains the agent versions and function support status. It's will be sent to the cloud via MQTT topic Advantech//update/platform/profile (since edgehub-agent 1.0.1)
  • Request Headers
  • Response 200 OK
    "agent:version:auth-server": "v1.9.1",
    "agent:version:edgehub-agent": "v1.0.2",
    "agent:version:edgex-helper": "v0.6.1",
    "agent:version:portal-service": "v1.0.1",
    "agent:version:rest-server": "v1.0.1",
    "apphub": 2,
    "host:display:count": 1,
    "host:info": 1,
    "hwmon": 1,
    "ibmc": 0,
    "model:name": "UNO-2484G-673xAE",
    "networking:interfaces": 5,
    "os": "windows",
    "os:arch": "x86_64",
    "os:description": "Microsoft Windows 10 Enterprise LTSC 2019",
    "perif:brightness": 0,
    "perif:disk": 1,
    "perif:gpio:all": 0,
    "perif:gpio:count": 0,
    "perif:led": 0,
    "perif:wdt": 1,
    "perif:wdt:enabled": false,
    "perif:wdt:timeoutInSeconds": 60,
    "perif:wdt:timeoutMaxInSeconds": 255,
    "perif:wdt:timeoutMinInSeconds": 10,
    "perif:wdt:type": "EC",
    "processes": 194,
    "service:list": 1,
    "system:ip": "172.16.12.123",
    "system:mac": "00:0b:ab:12:34:56",
    "systemperf": 1
    "Code": 401,
    "Message": ""
POST /edgehub/api/data​
Send tag data to the cloud. (since edgehub-agent 1.0.1)
  • Request Headers
  • Request Body
    "string_data": "abcdefg...",
    "number_data": 12345,
    "bool_data": true,
    The data has been sent successfully.
    "Code": 401,
    "Message": ""
  • Response 400 Bad Requset
    The request data is empty, invalid format, or incorrect value.
    "message": ""
    "message": ""
GET /edgehub/api/apphub/status​
Get the AppHub service running status. (since edgehub-agent 1.0.1)
  • Request Headers
  • Response 200 OK
    "status": "running",
    Note: The possible status values are "unknown or not available", "running", "stopped", "**unknown status: **"
    It indicates there is no AppHub service installed.
    "Code": 401,
    "Message": ""
PUT /edgehub/api/apphub/service​
Control the AppHub service status. (since edgehub-agent 1.0.1)
  • Request Headers
  • Request Body
    "Code": 401,
    "Message": ""
    "message": ""
PUT /edgehub/api/apphub/log/config​
Set up the AppHub log configuration. (since edgehub-agent 1.0.1)
  • Request Headers
  • Request Body
    1. Setup logFile and logLevel simultaneously.
      "logFile": true | false,
      "logLevel": "error" | "info"
    2. Setup logFile only.
    3. Setup logLevel only.
    "Code": 401,
    "Message": ""
    "message": ""
    "message": ""
GET /edgehub/api/edgebus/status​
Get the EdgeBus (Embedded Broker) running status. (since edgehub-agent 1.0.1)
  • Request Headers
  • Response 200 OK
    "enabled": true,
    "mqttBrokerStatus": {
    "version": "2.2.8",
    "started": 1683597812,
    "time": 1683786741,
    "uptime": 188929,
    "bytes_received": 1107413,
    "bytes_sent": 1090102,
    "clients_connected": 2,
    "clients_disconnected": 0,
    "clients_maximum": 2,
    "clients_total": 2,
    "messages_received": 10437,
    "messages_sent": 10489,
    "retained": 0,
    "inflight": 0,
    "inflight_dropped": 0,
    "subscriptions": 3,
    "packets_received": 23949,
    "packets_sent": 24001,
    "memory_alloc": 7553024,
    "threads": 75
    "clientStatus": "connected"
    It indicates there is no EdgeBus service support.
    "Code": 401,
    "Message": ""
PUT /edgehub/api/edgebus/config​
Set up the EdgeBus (Embedded Broker) configuration. (since edgehub-agent 1.0.1)
  • Request Headers
  • Request Body
    Enable or Disable the EdgeBus (Embedded Broker).
    "enabled": false
  • Response 200 OK
    Same as the request body.
    "enabled": false
    "Code": 401,
    "Message": ""
    "message": ""
POST /edgehub/api/pem/temp​
Upload a PEM file and encode it to a base64 string if the file is valid. (since edgehub-agent 1.1.0)
  • Request Headers
  • Request Body
    The request body must be multipart/form-data with a field name file and the value is the File containing the PEM data to upload.
  • Response 200 OK
    The type is the PEM file type, such as CERTIFICATE, PRIVATE KEY. The data is the base64-encoded PEM file content.
    "type": "CERTIFICATE",
    "data": ""
    "Code": 401,
    "Message": ""
    "message": ""
PUT /edgehub/api/bootstrap/config​
Set up the EdgeHub Mass Deployment configuration. (since edgehub-agent 1.5.1, edgehub-suite 1.4.0)
  • Request Headers
    Log in with the OS or the "admin" account to get a JWT token (token field from the response body).
  • Request Body
    The request body should contain the tenant access token obtained from the EdgeHub Mass Deployment tab.
    "tenantToken": "eyJ0eXA..."
    • tenantToken: The access token for the specific tenant you want to configure for mass deployment.
    The configuration has been successfully applied.
    "Code": 401,
    "Message": ""
    The request could not be processed due to invalid configuration data. The response will include a JSON object with:
    • message: A specific error message detailing the configuration error.
    "message": ""
On this page ...
Is this helpful?
