Python Edge SDK Manual
October 21, 2024
Environment
- Runtime
- Python: 3.6
- Pip: 1.8
- Python Package:
Installation
- Via the command line
pip install EdgeSync360-EdgeHub-Edge-Python-SDK
- Upgrade the package version
pip install EdgeSync360-EdgeHub-Edge-Python-SDK --upgrade
- Check the installed version
pip show EdgeSync360-EdgeHub-Edge-Python-SDK
Version: 1.0.0
Summary: EdgeSync360_EdgeHub_Edge_Python_SDK package allows developers to write Python applications which access the EdgeSync360/EdgeHub Platform via MQTT protocol.
Home-page: https://github.com/EdgeHub-Repo/dc-edge-sdk-python-sample
Author: Paul Tseng
Author-email: edgehub.dev@gmail.com
License:
Requires: paho-mqtt
Required-by:
FAQ
- The system displays the following SSL certificate error messages:
```json
[SSL: CERTIFICATE_VERIFY_FAILED] certificate verification failed (_ssl.c:720
- Windows
- Install Win 32/Win 64 OpenSSL.
- Mac OS
- You have two options:
- Run an install command shipped with Python 3.6.
cd /Applications/Python\ 3.6/
./Install\ Certificates.command
- Install the certification package with
pip install certifi
EdgeAgent
Constructor (EdgeAgentOptions options)
New EdgeAgent object
options = EdgeAgentOptions(
reconnectInterval = 1, # MQTT reconnect interval in seconds.
nodeId = '5095cf13-f005-4c81-b6c9-68cf038e2b87', # Get from portal
deviceId = 'device1', # If the type is Device, deviceId must be input.
type = constant.EdgeType['Gateway'], # Configure the edge as a Gateway or Device. The default setting is Gateway.
heartbeat = 60, # The default is 60 seconds.
dataRecover = True, # Whether to recover data when disconnected
connectType = constant.ConnectType['DCCS'], # Connection type (DCCS, MQTT). The default setting is DCCS.
MQTT = MQTTOptions( # If the connectType is MQTT, the following options must be input:
hostName = '127.0.0.1',
port = 1883,
userName = 'admin',
password = 'admin',
protocolType = constant.Protocol['TCP'] # MQTT protocol (TCP, WebSocket). The default is TCP.
DCCS = DCCSOptions(
APIURL = '', # DCCS API URL
credentialKey = '' # Credential key
AzureIotHub = AzureIotHub=AzureIotHubOptions(
connectionString='',
edgeAgent = EdgeAgent(options = options);
Azure IoT Hub
Due to the connection limit of the Azure IoT Hub SDK, the C# SDK can only connect to the Azure IoT Hub using a connection string. Therefore, you can only connect to the Edge Hub using a EdgeLink device.
Event
EdgeAgent has three subscription events.
- Connected: When EdgeAgent is connected to the IoTHub.
- Disconnected: When EdgeAgent is disconnected from the IoTHub.
- MessageReceived: When EdgeAgent receives an MQTT message from the cloud. The message types are as follows:
- WriteValue: Change the tag value from the cloud.
- WriteConfig: Change the config from the cloud.
- TimeSync: Returns the current time from the cloud.
- ConfigAck: Response to config uploads from the edge to the cloud.
edgeAgent.on_connected = edgeAgent_on_connected
edgeAgent.on_disconnected = edgeAgent_on_disconnected
edgeAgent.on_message = edgeAgent_on_message
def edgeAgent_on_connected(agent, isConnected):
print('Connection success')
def edgeAgent_on_disconnected(agent, isDisconnected):
print('Disconnected')
def edgeAgent_on_message(agent, messageReceivedEventArgs):
# messageReceivedEventArgs format: Model.Event.MessageReceivedEventArgs
type = messageReceivedEventArgs.type
message = messageReceivedEventArgs.message
if type == constant.MessageType['WriteValue']:
# message format: Model.Edge.WriteValueCommand
for device in message.deviceList:
print('deviceId: {0}'.format(device.Id))
for tag in device.tagList:
print('tagName: {0}, Value: {1}'.format(tag.name, str(tag.value)))
elif type == constant.MessageType['WriteConfig']:
print('WriteConfig')
elif type == constant.MessageType['TimeSync']:
# message format: Model.Edge.TimeSyncCommand
print(str(message.UTCTime))
elif type == constant.MessageType['ConfigAck']:
# message format: Model.Edge.ConfigAck
print('Upload Config Result: {0}'}.format(str(message.result)))
Connect ()
Connect to the IoTHub. When connected successfully, a connected event will be triggered.
edgeAgent.connect();
Disconnect ()
Disconnect from the IoTHub. When disconnected successfully, a disconnected event will be triggered.
edgeAgent.disconnect();
UploadConfig (ActionType action, EdgeConfig edgeConfig)
Upload Node/Device/Tag Config with Action Type (Create/Update/Delete).
config = EdgeConfig()
# set node config
# set device config
# set tag config
result = edgeAgent.uploadConfig(constant.ActionType['Create'], edgeConfig = config)
Node config setting
nodeConfig = NodeConfig(nodeType = constant.EdgeType['Gateway'])
config.node = nodeConfig
Device config setting
deviceConfig = DeviceConfig(
id = 'Device1',
name = 'Device 1',
deviceType = 'Device Type',
description = 'Description'
config.node.deviceList.append(deviceConfig)
Analog tag config setting
analogTag = AnalogTagConfig(
name = 'ATag',
description = 'AnalogTag',
readOnly = True,
arraySize = 0,
spanHigh = 10,
spanLow = 0,
engineerUnit = 'cm',
integerDisplayFormat = 2,
fractionDisplayFormat = 4
config.node.deviceList[0].analogTagList.append(analogTag)
Discrete Tag config setting
discreteTag = DiscreteTagConfig(
name = 'DTag',
description = 'DiscreteTag',
readOnly = False,
arraySize = 0,
state0 = '1',
state1 = '0',
state2 = None,
state3 = None,
state4 = None,
state5 = None,
state6 = None,
state7 = None
config.node.deviceList[0].discreteTagList.append(discreteTag)
Text tag config setting
textTag = TextTagConfig(
name = 'TTag',
description = 'TextTag',
readOnly = True,
arraySize = 0
config.node.deviceList[0].textTagList.append(textTag)
Block Config
Create block config:
blockConfig = BlockConfig(
blockType = 'Pump',
analogTagList = [
AnalogTagConfig(
name = 'ATag',
readOnly = True,
arraySize = 0,
spanHigh = 10,
spanLow = 0,
discreteTagList = [
DiscreteTagConfig(
name = 'DTag',
readOnly = False,
arraySize = 0,
state0 = '1',
state1 = '0',
state2 = None,
state3 = None,
state4 = None,
state5 = None,
state6 = None,
state7 = None
textTagList = [
TextTagConfig(
name = 'TTag',
readOnly = True,
arraySize = 0
This block config contain 3 tag, and the block type is `Pump`, using this block config create two block:
```python
deviceConfig.addBlock('Pump01',blockConfig)
deviceConfig.addBlock('Pump02',blockConfig)
This will add 6 tag to your device, the first 3 tag will have a prefix of Pump01 and the last 3 tag will have a prefix of Pump02, for example:
SendData (EdgeData data)
Send the tag values to the cloud.
edgeData = EdgeData()
for i in range(1, 3):
for j in range(1, 5):
deviceId = 'Device' + str(i)
tagName = 'ATag' + str(j)
value = random.uniform(0, 100)
tag = EdgeTag(deviceId, tagName, value)
edgeData.tagList.append(tag)
tagName = 'DTag' + str(j)
value = random.randint(0, 99) % 2
tagName = 'TTag' + str(j)
value = 'TEST ' + j
edgeData.timestamp = datetime.datetime.now()
#edgeData.timestamp = datetime.datetime(2020,8,24,6,10,8) # You can specify the time(local time) of data
result = edgeAgent.sendData(data = edgeData)
An array tag value must use Dictionary, T is defined according to the tag type. (Analog: double, Discrete: int, Text: string).
# analog array tag
dicVal = {
'0': 0.5,
'1': 1.42
tag = EdgeTag(deviceId = 'Device1', tagName = 'ATag', value = dicVal)
# discrete array tag
dicVal = {
'0': 0,
'1': 1
tag = EdgeTag(deviceId = 'Device1', tagName = 'DTag', value = dicVal)
# text array tag
dicVal = {
'0': 'zero',
'1': 'one'
tag = EdgeTag(deviceId = 'Device1', tagName = 'TTag', value = dicVal)
Send the tag values in batch to the cloud.
array = []
for n in range(1, 10):
value = 'TEST ' + j
array.append(edgeData)
result = edgeAgent.sendData(array)
SendDeviceStatus (EdgeDeviceStatus deviceStatus)
Send the device status to the cloud when the status is changed.
deviceStatus = EdgeDeviceStatus()
id = 'Device' + str(i)
status = EdgeStatus(id = id, status = constant.Status['Online'])
deviceStatus.deviceList.append(status)
result = edgeAgent.sendDeviceStatus(deviceStatus)
Property
| Property Name | Data Type | Description |
| isConnected | Boolean | Connection Status (read only) |
Sample Code
- GitHub
Release Note
- [1.0.2] - 2024-10-21
- Add
- Support Azure IoT Hub device connection which is created from EdgeHub
- Add
- [1.0.1] - 2024-09-09
- Add
- Support
BlockTypethat is defined in WISE-PaaS MQTT v1.0.16
- Support
- Add
- [1.0.0] - 2024-08-08
- Add
EdgeSync360 EdgeHub EdgeSDKProject initialized, derived from WISE-PaaS DataHub EdgeSDK
- Add
Release Note (Archived: WISE-PaaS DataHub EdgeSDK)
- [1.1.7] - 2021-09-29
- Added
- Support send data in batch for high frequency data
- Added
- [1.1.6] - 2021-09-09
- Changed
- Remove the mechanism for splitting huge data packages into many small packages
- Changed
- [1.1.5] - 2020-11-26
- Added
- Add logger for debugging
- Fixed
- Fix the problem that error log will appear when user doesn’t implement on_message event
- Removed
- TimeSync and WriteConfig of message received event
- Added
- [1.1.4] - 2020-09-15
- Fixed
- The array size of TagConfig set invalid issue
- Fixed
- [1.1.3] - 2020-08-30
- Fixed
- Using datetime.now() instead of datetime.utcnow() to specify EdgeData’s timestamp
- Fixed
- [1.1.2] - 2020-08-24
- Fixed
- Fix the default timestamp is in local time problem
- Fixed
- [1.1.1] - 2020-07-10
- Support to customize the time of data
- [1.1.0] - 2020-02-15
- Added
- Support the “Delsert” action of UploadConfig
- Add the “RetentionPolicyName” property to DeviceConfig. This will automatically bind the retention policy to a device on the cloud.
- Changed
- Remove the deprecation properties of NodeConfig: name and description
- Added
- [1.0.10] - 2018-10-15
- [1.0.9] - 2018-10-15
