C# Edge SDK Manual
October 21, 2024
Environment
Installing the NuGet package for your project
dotnet add package EdgeSync360.EdgeHub.Edge.DotNet.SDK
EdgeAgent
Constructor (EdgeAgentOptions options)
New EdgeAgent object.
EdgeAgentOptions options = new EdgeAgentOptions()
ConnectType = ConnectType.DCCS, // Connection type (DCCS, MQTT). The default is DCCS.
DCCS = new DCCSOptions() // If ConnectType is DCCS, the following options must be entered:
CredentialKey = "", // Credential Key
APIUrl = "" // DCCS API Url
MQTT = new MQTTOptions() // If ConnectType is MQTT, the following options must be entered:
HostName = "127.0.0.1",
Port = 1883,
Username = "admin",
Password = "admin",
ProtocolType = Protocol.TCP
AzureIoTHub = new AzureIoTHubOptions() // if ConnectType is AzureIoTHub, the following options must be entered:
HostName = "",
SASToken = ""
UseSecure = false,
AutoReconnect = true,
ReconnectInterval = 1000,
NodeId = "5095cf13-f005-4c81-b6c9-68cf038e2b87", // Get from portal
Type = EdgeType.Gateway, // Configure the edge type as Gateway or Device. The default is Gateway.
DeviceId = "SmartDevice1", // If the type is Device, the DeviceId must be entered.
Heartbeat = 60000, // The default is 60 seconds.
DataRecover = true // Configure whether to recover data when disconnected.
EdgeAgent edgeAgent = new EdgeAgent(options);
Azure IoT Hub
Due to the connection limit of the Azure IoT Hub SDK, the C# SDK can only connect to the Azure IoT Hub using a SASToken. Therefore, you can only connect to the Edge Hub using a SCADA device.
Event
EdgeAgent has three subscription events.
  • Connected: When EdgeAgent is connected to the IoTHub.
  • Disconnected: When EdgeAgent is disconnected from the IoTHub.
  • MessageReceived: When EdgeAgent receives an MQTT message from the cloud. The message types are as follows:
    • WriteValue: Change the tag value from the cloud.
    • WriteConfig: Change the config from the cloud.
    • ConfigAck: Response to a config upload from the edge to the cloud.
edgeAgent.Connected += edgeAgent_Connected;
edgeAgent.Disconnected += edgeAgent_Disconnected;
edgeAgent.MessageReceived += edgeAgent_MessageReceived;
private void edgeAgent_Connected(object sender, EdgeAgentConnectedEventArgs e)
// Connected
Console.WriteLine("Connect success!");
private void edgeAgent_Disconnected(object sender, DisconnectedEventArgs e)
// Disconnected
Console.WriteLine("Disconnected.");
private void edgeAgent_MessageReceived(object sender, MessageReceivedEventArgs e)
switch (e.Type)
case MessageType.WriteValue:
WriteValueCommand wvcMsg = (WriteValueCommand) e.Message;
foreach (var device in wvcMsg.DeviceList)
Console.WriteLine("DeviceId: {0}", device.Id);
foreach (var tag in device.TagList)
Console.WriteLine("TagName: {0}, Value: {1}", tag.Name, tag.Value.ToString() );
break;
case MessageType.WriteConfig:
break
case MessageType.ConfigAck:
ConfigAck cfgAckMsg = (ConfigAck) e.Message;
Console.WriteLine("Upload Config Result: {0}", cfgAckMsg.Result.ToString() );
break;
Connect()
Connect to the IoTHub. When successfully connected, a connected event will be triggered.
edgeAgent.Connect();
Disconnect()
Disconnect from the IoTHub. When successfully disconnected, a disconnected event will be triggered.
edgeAgent.Disconnect();
UploadConfig(ActionType action, EdgeConfig edgeConfig)
Upload Node/Device/Tag Config with Action Type (Create/Update/Delete).
EdgeConfig config = new EdgeConfig();
// set node condig
// set device config
// set tag config
bool result = _edgeAgent.UploadConfig( ActionType.Create, config ).Result;
Node Config:
config.Node = new EdgeConfig.NodeConfig();
Device Config:
EdgeConfig.DeviceConfig device = new EdgeConfig.DeviceConfig()
Id = "Device1",
Name = "Device1",
Type = "Smart Device 1",
Description = "Device 1"
Analog Tag Config:
EdgeConfig.AnalogTagConfig analogTag = new EdgeConfig.AnalogTagConfig()
Name = "Volt",
Description = "Volt",
ReadOnly = false,
ArraySize = 0
SpanHigh = 1000,
SpanLow = 0,
EngineerUnit = "V",
IntegerDisplayFormat = 4,
FractionDisplayFormat = 2,
SendWhenValueChanged = true // Data will only be sent when the value changed
Discrete Tag Config:
EdgeConfig.DiscreteTagConfig discreteTag = new EdgeConfig.DiscreteTagConfig()
Name = "DTag",
Description = "DTag" + j,
ReadOnly = false,
ArraySize = 0
State0 = "0",
State1 = "1",
State2 = "",
State3 = "",
State4 = "",
State5 = "",
State6 = "",
State7 = "",
Text Tag Config:
EdgeConfig.TextTagConfig textTag = new EdgeConfig.TextTagConfig()
Name = "Text",
Description = "Text",
ReadOnly = false,
ArraySize = 0,
Block Config
Create block config:
Name = "ATag",
Description = "ATag",
ReadOnly = false,
ArraySize = 0,
SpanHigh = 1000,
SpanLow = 0,
EngineerUnit = "V",
Name = "DTag",
Description = "DTag",
ReadOnly = false,
ArraySize = 0,
State0 = "0",
State1 = "1",
Name = "TTag",
Description = "TTag",
ReadOnly = false,
ArraySize = 0,
var blockConfig = new EdgeConfig.BlockConfig("Pump");
blockConfig.AnalogTagList.Add(analogTag);
blockConfig.DiscreteTagList.Add(discreteTag);
blockConfig.TextTagList.Add(textTag);
This block config contain 3 tag, and the block type is Pump, using this block config create two block:
device.AddBlock("Pump01", blockConfig);
device.AddBlock("Pump02", blockConfig);
This will add 6 tag to your device, the first 3 tag will have a prefix of Pump01 and the last 3 tag will have a prefix of Pump02, for example:
SendData(EdgeData data)
Send the tag value to the cloud.
Random random = new Random();
EdgeData data = new EdgeData();
for (int i = 1; i T is defined according to the tag type (Analog: double, Discrete: int, Text: string).
```c#
// analog array tag
Dictionary dicVal = new Dictionary();
dicVal.Add("0", 0.5); // The tag index is 0 and the value is 0.5
dicVal.Add("1", 1.42); // The tag index is 1 and the value is 1.42
dicVal.Add("2", 2.89); // The tag index is 2 and the value is 2.89
EdgeData.Tag aTag = new EdgeData.Tag()
DeviceId = "Device1",
TagName = "ATag",
Value = dicVal
// discrete array tag
dicVal.Add("0", 0); // The tag index is 0 and the value is 0
dicVal.Add("1", 1); // The tag index is 1 and the value is 1
dicVal.Add("2", 2); // The tag index is 2 and the value is 2
EdgeData.Tag dTag = new EdgeData.Tag()
TagName = "DTag",
Value = dicVal
// text array tag
dicVal.Add("0", "zero"); // The tag index is 0 and the value is "zero"
dicVal.Add("1", "one"); // The tag index is 1 and the value is "one"
dicVal.Add("2", "two"); // The tag index is 2 and the value is "two"
EdgeData.Tag tTag = new EdgeData.Tag()
TagName = "TTag",
Value = dicVal
Send the tag values in batch to the cloud.
HashSet dataset = new HashSet();
for ( int n = 1; n <= 10; n++ )
for ( int i = 1; i <= 1; i++ )
for ( int j = 1; j <= 5; j++ )
DeviceId = "Device" + i,
TagName = "ATag" + j,
Value = random.NextDouble()
TagName = "DTag" + j,
Value = j % 2
TagName = "TTag" + j,
Value = "TEST " + j.ToString()
data.TagList.Add( aTag );
data.TagList.Add( dTag );
data.TagList.Add( tTag );
dataset.Add( data );
bool result = edgeAgent.SendData( dataset ).Result;
SendDeviceStatus (EdgeDeviceStatus deviceStatus)
Send the device status to the cloud when the status changes.
EdgeDeviceStatus deviceStatus = new EdgeDeviceStatus();
for (int i = 1; i <= 2; i++)
EdgeDeviceStatus.Device device = new EdgeDeviceStatus.Device()
Id = "Device" + i,
Status = Status.Online
deviceStatus.DeviceList.Add(device);
deviceStatus.Timestamp = DateTime.Now;
bool result = edgeAgent.SendDeviceStatus(deviceStatus).Result;
Property
Property NameData TypeDescription
IsConnectedbooleanConnection status (read only)
Sample Code
Release Note
  • [1.0.2] - 2024-10-21
    • Add
      • Support Azure IoT Hub device connection which is created from EdgeHub
  • [1.0.1] - 2024-09-09
    • Add
      • Support BlockType that is defined in WISE-PaaS MQTT v1.0.16
  • [1.0.0] - 2024-08-08
    • Add
      • EdgeSync360 EdgeHub EdgeSDK Project initialized, derived from WISE-PaaS DataHub EdgeSDK
Release Note (Archived: WISE-PaaS DataHub EdgeSDK)
  • [1.1.3] - 2021-09-09
    • Added
      • Support send data in batch for high frequency data
  • [1.1.2] - 2021-07-27
    • Updated
      • Remove the strategy of splitting a huge data message into several smaller packets.
    • Removed
      • DataManipulate function.
  • [1.1.1] - 2020-12-14
    • Fixed
      • Custom timestamp SendData() is invalid
  • [1.1.0] - 2020-10-19
    • Added
      • Patameter “SendWhenValueChanged”: If it is true, data will only be sent when the value changed
    • Removed
      • Deprecate time sync function
  • [1.0.12] - 2020-10-15
    • Added
      • UpdateData() for History data manipulation
      • SendData() supports a message contains tag values with multi-timestamp
    • Removed
      • Remove deprecation properties of AnalogTagConfig
  • [1.0.11] - 2020-04-30
    • Added
      • Use NLog for error logging
    • Removed
      • Remove deprecation properties of NodeConfig and DeviceConfig
  • [1.0.9] - 2020-02-11
    • Updated
      • Upgrade related packages
  • [1.0.8] - 2020-02-11
    • Added
      • Add “Delsert” action to the UploadConfig function. Let the cloud directly apply the uploaded config by force.
      • Add a “RetentionPolicyName” property to the DeviceConfig class
    • Updated
      • Remove the “ID”, “Name”, and “Description” properties of the EdgeConfig.NodeConfig class
  • [1.0.7] - 2018-10-02
    • Updated
      • EdgeData Property
      • Split a huge data message into a couple of smaller packages (a data message contains 100 tags at most)
      • Redesign the message object class of MessageReceived
  • [1.0.6] - 2018-08-01
    • Added
      • “IsConnected” property
  • [1.0.5] - 2018-08-01
    • Added
      • Automatic reconnection mechanism
    • Fixed
      • Adjust Connect() and Disconnect() to async function
  • [1.0.4] - 2018-05-15
    • Fixed
      • Cannot use customize time in SendData()
  • [1.0.3] - 2018-05-14
    • Added
      • Support a DCCS connection mechanism
  • [1.0.2] - 2018-03-22
    • Added
      • Support data recovery
  • [1.0.1] - 2018-02-22
  • [1.0.0] - 2017-02-20
