Version: 2.6.0
Device Management​
[New]​
  • Support for WISE-4250-S214 (beta FW)
    • Include firmware OTA, configuration OTA, IO configurations
[Update]​
  • DPM API
    • Batch Provision CSV API: For EdgeLink and SCADA module, force the useSystemTime to false and the device mode to operational.
    • Device create API: remove unused API fields
    • Update unknow device API: remove unused API fields
  • Security Updates
    • Fixed CVE vulnerabilities in the following components:
      • DPM Cleaner
      • DPM API
Data Management​
[Update]​
  • Core
    • [dbmaster] Support mutation dcWriteTagValue API
[Fix]​
  • Core​
    • [api-portal] Do Not Change Parameter Usage for EPN Virtual Devices
    • [api-portal] Ensure Usernames are Compared in a Case-Insensitive Manner in SQL JOIN
    • [Evaluator] If the reference point refers to itself, once a bad quality occurs, it will cause all subsequent calculations to be marked as bad quality.
    • [Evaluator] Spaces in formulas cause calculation errors.
    • [Dataworker] For isensing format, the value was retrieved from the Val field, which caused incorrect readings. (need to use EgF field)
