Go Edge SDK Manual
October 21, 2024
Environment
Installation
  • Via the command line:
go get github.com/EdgeHub-Repo/dc-edge-sdk-golang
EdgeAgent
Constructor (EdgeAgentOptions options)
New EdgeAgent object.
options := agent.NewEdgeAgentOptions()                  // Set default value
options.NodeID = "" // Get from portal
options.DeviceID = "" // If the type is Device, the DeviceID must be entered.
options.Type = agent.EdgeType["Gateway"] // Configure the edge as a Gateway or Device. The default setting is Gateway.
options.ReconnectInterval = 1, // The MQTT reconnect interval in seconds. The default setting is 1.
options.HeartBeatInterval = 60 // The default setting is 60 seconds.
options.DataRecover = true // Whether to recover data when disconnected. The default setting is True.
options.ConnectType = agent.ConnectType["DCCS"] // Connection type (DCCS, MQTT,AzureIoTHub). The default setting is DCCS.
options.UseSecure = false
options.MQTT = &agent.MQTTOptions { // If connectType is MQTT, the following options must be input:
HostName: "127.0.0.1",
Port: 1883,
UserName: "admin",
Password: "admin",
ProtocolType: Protocol["TCP"], // MQTT protocol (TCP, WebSocket). The default setting is TCP.
options.DCCS = &agent.DCCSOptions { // If connectType is DCCS, the following options must be input:
URL: "", // DCCS API URL
Key: "", // Credential key
options.AzureIoTHubOptions = &agent.AzureIoTHubOptions { // If connectType is AzureIoTHub, the following options must be input:
ConnectionString : "",
edgeAgent := agent.NewAgent(options)
Azure IoT Hub
Due to the connection limit of the Azure IoT Hub SDK, the GO SDK can only connect to the Azure IoT Hub using a connection string. Therefore, you can only connect to the Edge Hub using a EdgeLink device.
Event
EdgeAgent has three subscription events.
  • Connected: When EdgeAgent is connected to the IoTHub.
  • Disconnected: When EdgeAgent is disconnected to the IoTHub.
  • MessageReceived: When EdgeAgent receives an MQTT message from the cloud. The message types are as follows:
    • WriteValue: Change the tag value from the cloud.
    • ConfigAck: Response to a config upload from the edge to the cloud.
edgeAgent.SetOnConnectHandler(onConnectHandler)
edgeAgent.SetOnDisconnectHandler(onDisconnectHandler)
edgeAgent.SetOnMessageReceiveHandler(onMessageReceiveHandler)
func onConnectHandler (a agent.Agent) {
fmt.Println("Connect success")
func onDisconnectHandler (a agent.Agent) {
func onMessageReceiveHandler (args agent.MessageReceivedEventArgs) {
msgType := args.Type
msg := args.Message
switch msgType {
case MessageType["WriteValue"]: // message format: WriteDataMessage
for _, device := range message.(agent.WriteDataMessage).DeviceList {
fmt.Println("DeviceID:", device.ID)
for _, tag := range device.TagList {
fmt.Println("TagName:", tag.Name, "Value:", tag.Value)
case MessageType["ConfigAck"]: // message format: ConfigAckMessage
fmt.Println(message.(agent.ConfigAckMessage).Result)
Connect ()
Connect to the IoTHub. When successfully connected, a connected event will be triggered.
edgeAgent.Connect()
Disconnect ()
Disconnect from the IoTHub. When successfully disconnected success, a disconnected event will be triggered.
edgeAgent.disconnect()
UploadConfig (ActionType action, EdgeConfig edgeConfig)
Upload Node/Device/Tag Config with Action Type (Create/Update/Delete).
config = agent.EdgeConfig()
result = edgeAgent.UploadConfig(agent.Action["Create"], config)
Node config setting
nodeConfig = agent.NewNodeConfig()
nodeConfig.SetType(agent.EdgeType["Gateway"])# EdgeType (Gatewat, Device)
// add node config
config.Node = nodeConfig
Device config setting
deviceConfig = agent.NewDeviceConfig("deviceID")
deviceConfig.SetName("DeviceName")
deviceConfig.SetType("Device Type")
deviceConfig.SetDescription("Description")
// add devices
nodeConfig.DeviceList = append(nodeConfig.DeviceList, deviceConfig)
Analog tag config setting
analogConfig = agent.NewAnaglogTagConfig("AnalogTag")
analogConfig.SetDescription("AnalogTag")
analogConfig.SetReadOnly(True)
analogConfig.SetArraySize(0)
analogConfig.SetSpanHigh(10)
analogConfig.SetSpanLow(0)
analogConfig.SetEngineerUnit("cm")
analogConfig.SetIntegerDisplayFormat(4)
analogConfig.SetFractionDisplayFormat(2)
// add tags
deviceConfig.AnalogTagList = append(deviceConfig.AnalogTagList, analogConfig)
Discrete tag config setting
discreteConfig = agent.NewDiscreteTagConfig("DiscreteTag")
discreteConfig.SetDescription("DiscreteTag")
discreteConfig.SetReadOnly(false)
discreteConfig.SetArraySize(2)
discreteConfig.SetState0("1")
discreteConfig.SetState1("0")
// discreteConfig.SetState2()
// discreteConfig.SetState3()
// discreteConfig.SetState4()
// discreteConfig.SetState5()
// discreteConfig.SetState6()
// discreteConfig.SetState7()
// add tags
deviceConfig.DiscreteTagList = append(deviceConfig.DiscreteTagList, discreteConfig)
Text tag config setting
textConfig = agent.NewTextTagConfig("TextTag")
textConfig.SetDescription("TextTag")
textConfig.SetReadOnly(true)
textConfig.SetArraySize(0)
// add tags
deviceConfig.TextTagList = append(deviceConfig.TextTagList, textConfig)
Block Config
Create block config:
 var blockConfig = agent.NewBlockConfig("Pump")
blockConfig.AnalogTagList = append(blockConfig.AnalogTagList, analogConfig)
blockConfig.DiscreteTagList = append(blockConfig.DiscreteTagList, discreteConfig)
blockConfig.TextTagList = append(blockConfig.TextTagList, textConfig)
for idx := 0; idx < analogNum; idx++ {
config := generateAnalogConfig(idx + 1)
blockConfig.AnalogTagList = append(blockConfig.AnalogTagList, config)
for idx := 0; idx < discreteNum; idx++ {
config := generateDiscreteConfig(idx + 1)
blockConfig.DiscreteTagList = append(blockConfig.DiscreteTagList,config)
for idx := 0; idx < textNum; idx++ {
config := generateTextConfig(idx + 1)
blockConfig.TextTagList = append(blockConfig.TextTagList, config)
This block config contain 3 tag, and the block type is Pump, using this block config create two block:
deviceConfig.AddBlock("Pump01", blockConfig)
deviceConfig.AddBlock("Pump02", blockConfig)
This will add 6 tag to your device, the first 3 tag will have a prefix of Pump01 and the last 3 tag will have a prefix of Pump02, for example:
NWROM2p
SendData (EdgeData data)
Send a tag value to the cloud
// deviceNum: 3
// tagNum: 5
for i := 1; i < 4; i++ {
for j := 1; j &lt; 6; j++ {
deviceID := fmt.Sprintf(&quot;%s%d&quot;, &quot;Device&quot;, i)
tagName := fmt.Sprintf(&quot;%s%d&quot;, &quot;ATag&quot; + j)
value := random.uniform(0, 100)
tag := agent.EdgeTag{
DeviceID: deviceID,
TagName: tagName,
Value: value,
edgeData.TagList = append(edgeData.TagList, tag)
for j := 1; j < 6; j++ {
tagName := fmt.Sprintf(&quot;%s%d&quot;, &quot;DTag&quot; + j)
value := random.randint(0,99)
value = value % 2
DeviceID: deviceID,
TagName: tagName,
Value: value,
tagName := fmt.Sprintf(&quot;%s%d&quot;, &quot;TTag&quot; + j)
value = random.uniform(0, 100)
value = &quot;TEST&quot; + str(value)
tag = EdgeTag(deviceID, tagName, value)
DeviceID: deviceID,
TagName: tagName,
Value: value,
result = edgeAgent.SendData(edgeData)
An array tag value must use “map”. The value is defined according to the tag type. (Analog: float64, Discrete: int32, Text: string).
# analog array tag
dicVal := map[string]int {
&quot;0&quot;: 0.5,
&quot;1&quot;: 1.42,
DeviceID: &quot;deviceID&quot;,
TagName: &quot;ATag&quot;,
Value: dicVal
# discrete array tag
dicVal = map[string]int {
&quot;0&quot;: 0,
&quot;1&quot;: 1,
tag = agent.EdgeTag{
TagName: &quot;DTag&quot;,
Value: dicVal.
# text array tag
&quot;0&quot;: &quot;zero&quot;,
&quot;1&quot;: &quot;one&quot;
TagName: &quot;TTag&quot;,
Value: dicVal
SendDeviceStatus (EdgeDeviceStatus deviceStatus)
Send the device status to the cloud when the status is changed.
status := agent.EdgeDeviceStatus{
TimeStamp: time.Now(),
// deviceNum: 3
s := {
ID: fmt.Sprintf(&quot;%s%d&quot;, &quot;Device&quot;, i),
Status: agent.Status[&quot;Online&quot;], // Online, Offline
status.DeviceList = append(status.DeviceList, s)
result = edgeAgent.SendDeviceStatus(status)
Property
Property NameData TypeDescription
IsConnectedBooleanConnection Status (read only)
Sample Code
Release Note
  • [1.0.2] - 2024-10-21
    • Add
      • Support Azure IoT Hub device connection which is created from EdgeHub
  • [1.0.1] - 2024-09-09
    • Add
      • Support BlockType that is defined in WISE-PaaS MQTT v1.0.16
  • [1.0.0] - 2024-08-08
    • Add
      • EdgeSync360 EdgeHub EdgeSDK Project initialized, derived from WISE-PaaS DataHub EdgeSDK
Release Note (Archived: WISE-PaaS DataHub EdgeSDK)
  • [1.0.8] - 2021-09-09
    • Added
      • Add “SendWhenValueChanged” parameter in AnalogTagConfig, DiscreteTagConfig, and TextTagConfig
  • [1.0.7] - 2021-09-09
  • [1.0.6] - 2020-10-13
    • Fixed
      • Fix customized timestamp parsing incorrect
  • [1.0.5] - 2020-09-30
    • Fixed
      • Solved some package lost after reconnecting from losing internet connection in macOS and Linux
      • Able to upload the self-bring-in timestamp in SendData()
  • [1.0.4] - 2020-08-07
    • Added
      • Use go mod to manage libraries
    • Fixed
      • MQTT over SSL connection issue
      • Data recovery issue
  • [1.0.3] - 2020-02-18
    • Added
      • Automatic rounding down of tag value by “FractionDisplayFormat”
      • Keep the last uploaded config for internal data processing
  • [1.0.2] - 2019-12-27
    • Added
      • Add the “RetentionPolicyName” property to DeviceConfig. This will automatically bind the Retention Policy to your device on the cloud.
    • Changed
      • Remove the deprecation properties of NodeConfig: name and description
  • [1.0.1] - 2019-12-04
    • Added
      • Add “Delsert” action of config uploading
    • Fixed
      • Real-time data is always delayed by a couple of seconds
      • Some panic issues
  • [1.0.0] - 2019-11-20
