REST APIs
All Platform Portal functionality is built on REST APIs that developers can call directly to access resources and control their devices programmatically.
Authentication
GET /auth/ping
Ping the server to see if it is still alive.
Response
200 OK-
Body
pong
GET /auth/agentinfo
Get the agent information. (since v1.8.1)
Response
200 OKRequest Successfully
Body
"version": "v1.8.1"
GET /auth/version
Get the API version. (since v1.7.1)
Response
Body
"version":1.2
GET /auth/token{?m}
Get with the OS or the admin account and return the JWT token if the user is valid.
A request contains a header field in the form of Authorization: Basic , where credentials are the Base64 encoding of username and password joined by a single colon :
username:password => (base64) => dXNlcm5hbWU6cGFzc3dvcmQ=
(since v1.7.1, API version 1.1)
URI Parameters
m
number(optional) - User account type. (since v1.8.1, API version 1.2)0: OS account (default)2:adminaccount (default password:p@ssw0rd, must be changed after login)
Request Header
Authorization: Basic -
Response
200 OKLogin Successfully
Body
"code": 200
"expire":"20XX-XX-XXT14:08:33+08:00"
"token": ""
Cookie (if available)
Secure and HttpOnly cookies
Key: jwt
Value:
Response
401 UnauthorizedLogin Failed
"Code": 401,
"Message": ""
POST /auth/login{?m}
Log in with the OS or admin account and return the JWT token if the user is valid.
URI Parameters
m
number(optional) - User account type. (since 1.8.1, API version 1.2)0: OS account (default)2:adminaccount (default password:p@ssw0rd, must be changed after login)
Request body
"username": "your_username",
"password": "your_password"
Response
Body
"code": 200
"token": ""
Key: jwt
Value:
Response
"Code": 401,
"Message": ""
POST /auth/logout
Log out and clear the cookie.
Response
200 OK{
"code": 200
GET /auth/certificate
Download the JWT certificate file in the PEM format.
Response
200 OKHeaders
Content-Type: application/octet-stream
Content-Description: File Transfer
Content-Transfer-Encoding: Binary
Content-Disposition: attachment; filename=cert.pem.crt
PUT /auth/user/admin/password
Change the admin’s password. (since 1.8.1, API version 1.2)
Request Headers
Log in with the
adminaccount to get the JWT token (tokenfield from the response body).Authorization: Bearer -
Request Body
"old": "",
"new": "",
Response
200 OK -
Response
400 Bad Request{
"code": 400, // optional
"message": ""
Response
401 Unauthorized{
"code": 401,
"message": ""
Response
422 Unprocessable EntityThe request has been applied, but the request body is invalid.
"errors": {
"validator": ""
DELETE /auth/user/admin/password
Reset the admin’s password to the default value (p@ssw0rd). (since 1.8.1, API version 1.2)
Request Headers
Log in with the
Response
200 OK -
Response
400 Bad Request{
"message": ""
Response
401 Unauthorized{
"code": 401,
"message": ""
H/W Monitor
GET /platform/api/hwmon
Get all H/W Monitor data, including Temperature, Voltage, Current, and Fan Speed.
Request Headers
Log in with your OS account or the
Response
200 OK{
"temperature": [
"name": "CPU",
"value": "50.1",
"unit": "Celsius"
"voltage": [
"name": "VCore",
"value": "0.92",
"unit": "Volt"
"name": "12V",
"value": "11.86",
"unit": "Volt"
"current": [
"name": "OEM0",
"value": "0.54",
"unit": "A"
"fanspeed": [
"name": "FAN0",
"value": "1234",
"unit": "RPM"
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
404Not supported or no available data.
GET /platform/api/hwmon (SSE)
Get all H/W Monitor data, including Temperature, Voltage, Current, and Fan Speed via Server-Sent Events (SSE).
EventStream
event: message
data: {"current":[{"name":"OEM0","value":0.34, "unit":"A"}],"temperature":[{"name":"CPU","value":41, "unit":"Celsius"}],"voltage":[{"name":"Vcore", "value":0.92,"unit":"Volt"},{"name":"12V","value":11. 86,"unit":"Volt"},{"name":"5V Standby","value":4.95, "unit":"Volt"},{"name":"CMOS Battery","value":3.05, "unit":"Volt"}]}
GET /platform/api/hwmon/temperatures
Get H/W Monitor temperature data.
Request Headers
Response
200 OK```json
[ { "name": "CPU", "value": 40, "unit": "Celsius" }, ... ]
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
GET /platform/api/hwmon/voltages
Get H/W Monitor voltage data.
Request Headers
Response
200 OK```json
[ { "name": "Vcore", "value": 0.92, "unit": "Volt" }, ... ]
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
GET /platform/api/hwmon/currents
Get H/W Monitor current data.
Request Headers
Response
200 OK```json
[ { "name": "OEM0", "value": 0.54, "unit": "A" }, ... ]
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
404 Not FoundNot supported or no available data.
GET /platform/api/hwmon/fanspeeds
Get H/W Monitor fan speed data.
Request Headers
Response
200 OK```json
[ { "name": "FAN0", "value": 1234, "unit": "RPM" }, ... ]
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
Platform
GET /platform/api/ping
Response
200 OK-
Body
pong
GET /platform/api/agentinfo
Get the agent information. (since v0.14.1)
Response
Body
"version": "v0.14.1"
Portal
GET /api/ping
Ping the portal-service server to see if it is still alive.
Response
200 OK-
Body
pong
GET /api/agentinfo
Get the portal-service agent information. (since v0.14.1)
Response
Body
GET /api/irtm/ping
Ping the iFactory RTM server to see if it is still alive.
Response
200 OK-
Body
pong
System Information
Host Information
GET /platform/api/host/info
Get host information, including BIOS information, Boot Count, Boot Time, Device Name (BIOS Name), OS Information, and Image Information (if available).
Request Headers
Response
200 OK{
"biosSerialNumber": "Default string",
"biosUUID": "03000200-0400-0500-0006-000700080009",
"biosVersion": "N/A",
"bootCount": 22862,
"bootTime": 1619413851,
"deviceName": "UNO-2484G-673xAE",
"dockerVersion": "Docker version 19.03.13, build 4484c46d9d",
"ecVersion": "0.5",
"hostid": "d6d6752c-a6d4-4d02-96b1-96e2d3a8d2b2",
"hostname": "UNO-2484G-673xA",
"imageVersion": "6.04 Build 005",
"kernelArch": "x86_64",
"os": "windows",
"platform": "Microsoft Windows 10 Enterprise LTSC 2019",
"releaseDate": "01/23/2019",
"upTime": 851779
Response
401 Unauthorized{
"Code": 401,
"Message": ""
GET /platform/api/host/display/count
Get available display count.
Prerequisite
- rest-server 0.12.1.0 and later
Request Headers
Response
200 OK1 -
Response
401 Unauthorized{
"Code": 401,
"Message": ""
GET /platform/api/host/screenshot/:index
Get the specified display screenshot by index
Prerequisite
Request Headers
Response
200 OK{
"data": "",
"mediaType": "image/png"
}You can use Data URLs to render the response base64 encoded image.
data:[][;base64], -
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
422 Unprocessable EntityThe request has been applied but got errors.
"errors": {
"Host": ""
GET /platform/api/host/screenshot/:index/file
Get the specified display screenshot file by index
Prerequisite
Request Headers
Response
200 OKReturns the screenshot image file directly
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
"errors": {
"Host": ""
System Performance
GET /platform/api/systemperf
Get CPU, Memory information, and usage.
Request Headers
Response
200 OK{
"cpu": {
"info": {
"cpu": 0,
"vendorId": "GenuineIntel",
"family": "6",
"model": "78",
"stepping": 3,
"physicalId": "0",
"coreId": "0",
"cores": 1,
"modelName": "Intel(R) Core(TM) i7-6600U CPU @ 2.60GHz",
"mhz": 2600,
"cacheSize": 4096,
"flags": [
"sse",
"sse2",
"microcode": "0xc6"
"usage": [
0,
0,
0.9999999999990905,
0
"memory": {
"total": 8265986048,
"available": 7532920832,
"used": 415899648,
"usedPercent": 5.031458383608441,
"free": 6488629248,
Response
401 Unauthorized{
"Code": 401,
"Message": ""
GET /platform/api/systemperf/cpu
Get CPU information and usage.
Request Headers
Response
200 OK{
"info": {
"cpu": 0,
"family": "6",
"model": "78",
"stepping": 3,
"physicalId": "0",
"coreId": "0",
"cores": 1,
"mhz": 2600,
"cacheSize": 4096,
"flags": [
"sse",
"sse2",
"microcode": "0xc6"
"usage": [
1.5625,
0,
1.5625,
0
Response
401 Unauthorized{
"Code": 401,
"Message": ""
GET /platform/api/systemperf/memory
Get memory information and usage.
Request Headers
Response
200 OK{
"available": 7532576768,
"used": 417800192,
"usedPercent": 5.05445072824783,
"free": 6486446080,
Response
401 Unauthorized{
"Code": 401,
"Message": ""
System Devices
GET /platform/api/devmgr
Get a list of the hardware attached to the computer.
Request Headers
Response
200 OK```json
[ { "class": "ACPI", "instancePath": "ACPI\PNP0000\4&15FBC11C&0", "name": "Programmable interrupt controller", "status": "stopped" }, { "class": "STORAGE", "instancePath": "STORAGE\VOLUME\{7963B29A-147B-11EB-92A9-806E6F6E6963}#000000002F900000", "name": "Volume", "status": "running" }, { "class": "STORAGE", "instancePath": "STORAGE\VOLUME\{7963B29A-147B-11EB-92A9-806E6F6E6963}#000000001F500000", "name": "Volume", "status": "running" }, { "class": "PCI", "instancePath": "PCI\VEN_8086&DEV_9D15&SUBSYS_72708086&REV_F1\3&11583659&0&E0", "name": "PCI-to-PCI Bridge", "vendorID": "8086", "deviceID": "9D15", "status": "running" }, { "class": "USB", "instancePath": "USB\VID_05E3&PID_0612\5&2C705BFE&0&15", "name": "Generic SuperSpeed USB Hub", "vendorID": "05E3", "deviceID": "0612", "status": "running" } ]
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
"errors": {
"DevMgr": ""
Service
(since rest-server 1.0.1)
GET /platform/api/service/list
Get the service list
Request Headers
Response
200 OK```json
[ { "name": "AppHubEdgeService", "displayName": "AppHub-Edge Service", "description": "", "status": "running" }, { "name": "ALG", "displayName": "Application Layer Gateway Service", "description": "Provides support for 3rd party protocol plug-ins for Internet Connection Sharing", "status": "stopped" }, .. ]
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
"errors": {
"Service": ""
GET /platform/api/service/:name
Get the service status by name.
Request Headers
Response
200 OKThe available status will be "running", "stopped", "disabled", or "unknown".
"status": "running"
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
"errors": {
"Service": ""
PUT /platform/api/service/:name
Control the service status by name.
Request Headers
Request Body
"action": "start" | "stop" | "restart"
Response
204 No ContentThe requested operation is successful.
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
"errors": {
"Service": ""
Terminal
GET /platform/api/term/ws
Get the web terminal basic information.
Request Headers
Response
200 OK{
"os": "windows" | "linux",
Response
401 Unauthorized{
"Code": 401,
"Message": ""
GET wss://(URL)/platform/api/term/ws
Open a local shell, making it communicate to WebSocket using stdin/stdout.
Request Headers
Message Description
- Message Format
Outbound Message ↑
Cmd Data Description 1 base64-encoded terminal output terminal output 2 Pong message (heartbeat) 3 The New Title Set window title 4 {"font-size":12,"font-family":"serif"} Set Preferences 5 false Set auto reconnect 6 1024 Set Buffer Size -
Inbound Message ↓
Cmd Data Description 1 base64-encoded terminal input terminal input data 2 Ping message 3 {"columns":128,"rows":21} Resize Terminal
- Message Format
Peripheral
LED
GET /platform/api/perif/led
Get an LED list with high-low values.
Request Headers
Response
200 OKtrue -> logical high, false -> logical low
```json
[ true, false, true, false, true, false, true, true ]
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
GET /platform/api/perif/led/:id
Get the specified LED value by index (id)
Request Headers
Response
true | false -
Response
400 Bad Request{
"errors": {
"LED": ""
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
PUT /platform/api/perif/led/:id
Set the value of the specified LED by index (id)
Request Headers
Request Body
"status": true | false
Response
200 OK -
Response
400 Bad RequestInvalid Parameters Error
"errors": {
"LED": ""
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
Response
422 Unprocessable EntityThe request body has missing parameters.
"errors": {
"validator": ""
}The request has been applied but got errors.
"errors": {
"LED": ""
Watchdog
GET /platform/api/perif/wdt
Get hardware watchdog information.
Request Headers
Response
200 OK{
"enabled": ,
"type": "EC Watchdog",
"timeoutInSeconds": 15,
"timeoutMaxInSeconds": 255,
"timeoutMinInSeconds": 10
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
Response
"errors": {
"WDT": ""
PUT /platform/api/perif/wdt
Set hardware watchdog enabled or disabled with provided timeout value (optional).
Request Headers
Request Body
The
secondsvalue range is [timeoutMinInSeconds, timeoutMaxInSeconds]{
"enabled": , // required
"seconds": [timeoutMinInSeconds, timeoutMaxInSeconds], // optional
Response
200 OK{
"enabled": ,
"seconds":
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
Response
"errors": {
"WDT": ""
PUT /platform/api/perif/wdt/timeout
Set hardware watchdog timeout value (in seconds).
Request Headers
Request Body
The
Response
200 OK{
"seconds":
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
Response
"errors": {
"WDT": ""
Disk
GET /platform/api/perif/disk
Get installed harddisk information, including model name, size, partition list, usage, and S.M.A.R.T. information (if available).
Request Headers
Response
200 OK```json
[ { "name": "\\.\PHYSICALDRIVE0", "sizeBytes": 64017354240, "physicalBlockSizeBytes": 0, "removable": false, "vendor": "(Standard disk drives)", "model": "SQF-S25M4-64G-S9C", "serialNumber": "XXXXXXXXXXXXX", "firmwareRevision": "XXXXX8", "mediaType": "Fixed hard disk media", "partitions": [ { "mountPoint": "C:", "sizeBytes": 63208157184, "freeBytes": 47287078912, "usedBytes": 15921078272, "usedPercent": 25.188328502685938, "readOnly": false } ], "smartAttributes": [ { "id": 1, "name": "Read Error Rate", "statusFlags": 10, "value": 100, "worst": 100, "threshold": 50, "rawData": [ 0, 0, 0, 0, 0, 0 ]
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
GET /platform/api/perif/disk (SSE)
Get installed hard disk information via Server-Sent Events (SSE), including model name, size, partition list, usage, and S.M.A.R.T. information (if available).
EventStream
event: message
data: [{"name":"\\\\.\\PHYSICALDRIVE0","sizeBytes":64017354240,"physicalBlockSizeBytes":0,"removable":false,"vendor":"(Standard disk drives)","model":"SQF-S25M4-64G-S9C","serialNumber":"FF73076C030806395366","firmwareRevision":"S9FMA028","mediaType":"Fixed hard disk media","partitions":[{"mountPoint":"C:","sizeBytes":63208157184,"freeBytes":27825188864,"usedBytes":35382968320,"usedPercent":55.97848425955465,"readOnly":false}],"smartAttributes":[{"id":1,"name":"Read Error Rate","statusFlags":10,"value":100,"worst":100,"threshold":50,"rawData":[0,0,0,0,0,0]},{"id":9,"name":"Power-On Hours (POH)","statusFlags":18,"value":100,"worst":100,"threshold":0,"rawData":[118,38,0,0,0,0]},{"id":12,"name":"Power Cycle Count","statusFlags":18,"value":100,"worst":100,"threshold":0,"rawData":[219,0,0,0,0,0]},{"id":168,"name":"Vendor Specific","statusFlags":18,"value":100,"worst":100,"threshold":0,"rawData":[0,0,0,0,0,0]},{"id":170,"name":"Vendor Specific","statusFlags":3,"value":86,"worst":86,"threshold":10,"rawData":[52,0,0,0,0,0]},{"id":173,"name":"Vendor Specific","statusFlags":18,"value":100,"worst":100,"threshold":0,"rawData":[203,11,158,0,0,0]},{"id":192,"name":"Power-off Retract Count","statusFlags":18,"value":100,"worst":100,"threshold":0,"rawData":[21,0,0,0,0,0]},{"id":194,"name":"Temperature","statusFlags":35,"value":70,"worst":70,"threshold":0,"rawData":[30,0,0,0,0,0]},{"id":218,"name":"Vendor Specific","statusFlags":11,"value":100,"worst":100,"threshold":50,"rawData":[0,0,0,0,0,0]}]}]
GET /platform/api/perif/disk/partition
Get the partition list of installed disks.
Request Headers
Response
200 OK```json
[ { "mountPoint": "C:", "sizeBytes": 63208157184, "freeBytes": 27825188864, "usedBytes": 35382968320, "usedPercent": 55.97848425955465, "readOnly": false } ]
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
Redundant Power
GET /platform/api/perif/redundant_power
Get redundant power status.
Request Headers
Response
200 OK1: online 0: offline
"vin1State": 0 | 1,
"vin2State": 0 | 1
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
GET /platform/api/perif/redundant_power (SSE)
Get redundant power status via Server-Sent Events (SSE).
EventStream
event: message
data: {
"vin1State": 0 | 1,
"vin2State": 0 | 1
GPIO
(since rest-server v0.15.1)
GET /platform/api/perif/gpio/count
Get available GPIO count.
Request Headers
Response
200 OK{
"count": 8,
Response
401 Unauthorized{
"Code": 401,
"Message": ""
GET /platform/api/perif/gpio/all
Get all the available GPIO pins configuration.
Request Headers
Response
200 OK```json
[ { "pin": 0, // 0-based pin index (:id) "dir": 0, // direction. 0: output, 1: input "level": 0 // level. 0: low, 1: high }, { "pin": 1, "dir": 1, "level": 1 }, ... { "pin": 7, "dir": 1, "level": 1 } ]
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
Response
"errors": {
"GPIO": ""
GET /platform/api/perif/gpio/:id
Get the specified GPIO pin (by index :id) direction and level.
Request Headers
Response
200 OK{
"dir": 0, // dir. 0: output, 1: input
"level": 0, // level. 0: low, 1: high
Response
400 Bad RequestInvalid parameter (incorrect
:id){
"errors": {
"GPIO": "invalid parameter"
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
Response
"errors": {
"GPIO": ""
GET /platform/api/perif/gpio/:id/dir
Get the specified GPIO pin (by index :id) direction.
0: output, 1: input
Request Headers
Response
200 OK{
Response
:id){
"errors": {
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
Response
"errors": {
"GPIO": ""
PUT /platform/api/perif/gpio/:id/dir
Set the specified GPIO pin (by index :id) direction.
Request Headers
Request Body
0: output,1: input{
"dir": 0 | 1
Response
200 OK -
Response
:id){
"errors": {
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
Response
"errors": {
"validator": ""
Response
"errors": {
"GPIO": ""
GET /platform/api/perif/gpio/:id/level
Get the specified GPIO pin (by index :id) level.
0: low, 1: high
Request Headers
Response
200 OK{
Response
:id){
"errors": {
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
Response
"errors": {
"GPIO": ""
PUT /platform/api/perif/gpio/:id/level
Set the specified GPO pin (by index :id) level.
Request Headers
Request Body
0: low,1: high{
"level": 0 | 1
Response
200 OK -
Response
:id){
"errors": {
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
Response
"errors": {
"validator": ""
Response
"errors": {
"GPIO": ""
Brightness
(since rest-server v0.16.1)
GET /platform/api/perif/brightness
Get the brightness information, including brightness minimum, maximum, and value.
Request Headers
Response
200 OK{
"min": 0, // the supported minimum brightness value
"max": 9, // the supported maximum brightness value
"value": 5, // the current brightness value
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
"errors": {
"Brightness": ""
PUT /platform/api/perif/brightness
Set the brightness value.
Request Headers
Request Body
"value": 1
Response
200 OK -
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
"errors": {
"Brightness": ""
Networking
GET /platform/api/networking/interfaces
Get network adapters' information and the current IP configuration.
Request Headers
Response
200 OKEmpty if there is no network adapter found.
```json
[ { "ifIndex": 2, "uuid": "enp0s31f6", "name": "enp0s31f6", "description": "", "type": "Ethernet", "typeId": 1, "mtu": 1500, "connected": true, "isDefault": false, "hardwareAddress": "xx:xx:xx:xx:xx:xx", "speed": "1 Gbps", "sendSpeed": 1000000000, "recvSpeed": 1000000000, "addresses": [ "172.16.12.91/23", "fe80::6543:2799:56b0:78b/64" ], "gateway": [ "192.168.6.1" ], "dns": [ "192.168.6.1" ], "iocounters": { "ifindex": 2, "bytesSent": 518832090, "bytesRecv": 5103663236, "packetsSent": 593021, "packetsRecv": 58711134, "errin": 0, "errout": 0, "dropin": 0, "dropout": 0, "fifoin": 0, "fifoout": 0 } }, { "ifIndex": 3, "uuid": "enp1s0", "name": "enp1s0", "description": "", "type": "Wi-Fi", "typeId": 71, "mtu": 1500, "connected": false, "isDefault": false, "hardwareAddress": "xx:xx:xx:xx:xx:xx" },
Response
401 Unauthorized{
"Code": 401,
"Message": ""
GET /platform/api/networking/interfaces (SSE)
Get network adapters' information and the current IP configuration via Server-Sent Events (SSE).
EventStream
event: message
data: [{"ifIndex":17,"uuid":"{B30C1205-A9C3-4155-9E01-0AB4D5A36DB4}","name":"Ethernet 4","description":"Intel(R) Ethernet Connection I219-LM","type":"Ethernet","typeId":6,"mtu":1500,"connected":true,"isDefault":false,"dhcpEnabled":true,"hardwareAddress":"74:FE:48:05:0A:EE","sendSpeed":1000000000,"recvSpeed":1000000000,"addresses":["172.16.12.60/23","fe80::4013:3d5e:69a7:460a/64"],"gateway":["172.16.13.254"],"dns":["172.20.1.99","8.8.8.8"],"dnssuffix":"ADVANTECH.CORP","ipv4Metric":1,"ipv6Metric":25,"iocounters":{"ifindex":17,"bytesSent":2721740020,"bytesRecv":6232829747,"packetsSent":4159260,"packetsRecv":3706395,"errin":0,"errout":0,"dropin":0,"dropout":0,"fifoin":0,"fifoout":0}},...]
POST /platform/api/networking/interfaces/route
Change the sequence of the network interface route (metric).
Request Headers
Request Body
The
sortedGUIDListis an interface uuid list by order of priority.{
"ipv6": false,
"sortedGUIDList": [
"{53E59828-224E-4416-9A05-DE95EB7F4C4A}",
"{EFCDC03D-30CA-434D-B284-DB517179D7FD}",
"{D1A142DB-C5F9-40D4-9F1B-A1FE2BE89C33}",
"{5A0E29AC-4767-4EAB-A2F5-F718F343B198}",
"{D09F45AC-3A17-4012-B278-45B923978278}",
"{94CDC116-21A5-4419-90AF-F0626B643566}",
"{1BB8C682-3B29-47A6-9504-44542CAF918E}"
Response
201 Created -
Response
400 Bad RequestThe request has been applied but got errors.
"errors": {
"networking": ""
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
"errors": {
"validator": ""
}The
sortedGUIDListis empty or not provided.{
"errors": {
"networking": "empty list"
PUT /platform/api/networking/ipv4config/:ifIndex
Sets the IPv4 configuration with static IP and DNS. You can call GET /platform/api/networking/interfaces to get the ifIndex.
Request Headers
Request Body
"ipAddress": "xxx.xxx.xxx.xxx",
"subnetMask": "xxx.xxx.xxx.xxx",
"defaultGateway": "xxx.xxx.xxx.xxx",
"primaryDNS": "xxx.xxx.xxx.xxx",
"secondaryDNS": null // optional
- Response
200 OK
"ipAddress": "",
"subnetMask": "",
"defaultGateway": "",
"primaryDNS": "",
"secondaryDNS": ""
Response
"errors": {
"validator": ""
"errors": {
"Net": ""
DELETE /platform/api/networking/ipv4config/:ifIndex
Enable DHCP for the specified interface. You can call GET /platform/api/networking/interfaces to get the ifIndex.
Request Headers
Response
200 OK -
Response
422 Unprocessable EntityThere are missing parameters.
"errors": {
"Net": ""
"errors": {
"Net": ""
GET /platform/api/networking/wifi/interfaces
Get Wi-Fi adapters information.
Request Headers
Response
```json
[ { "ifIndex": 14, "uuid": "{94CDC116-21A5-4419-90AF-F0626B643566}", "description": "802.11n USB Wireless LAN Card", "profiles": [ { "name": "SQA_2.4G", "allUserProfile": true, "groupPolicyProfile": false, "perUserProfile": false } ]
Response
401 Unauthorized{
"Code": 401,
"Message": ""
GET /platform/api/networking/wifi/networks/:uuid
Get a list of all available networks of the specified Wi-Fi adapter selected by uuid.
Request Headers
Response
200 OKEmpty if there is no available network found.
```json
[ { "alreadyConnected": true, "authenticationAlgorithm": "WPA2-Personal", "channel": 7, "cipherAlgorithm": "AES", "connectable": true, "infrastructureType": "Infrastructure", "profileAvailable": true, "profileName": "SQA_2.4G", "ssid": "SQA_2.4G", "securityEnabled": true, "signalQuality": 100, "signalStrength": -50, "bssid": "E0:3F:49:00:04:30", "physicalTypes": [ "802.11n" ]
"alreadyConnected": false,
"profileAvailable": false,
"profileName": "",
"ssid": "FIVEGGGGGHZ",
"signalQuality": 30,
"signalStrength": -85,
"physicalTypes": [
"802.11ac"
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
"errors": {
"WiFi": ""
DELETE /platform/api/networking/wifi/interface/:uuid/profile/:name
Delete the connected network profile (selected by profile name) of the specified Wi-Fi interface (selected by uuid)
Request Headers
Response
200 OKProfile deleted.
Response
400 Bad RequestThe profile name is empty.
"errors": {
"WiFi": "invalid profile name"
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
"errors": {
"WiFi": ""
Process Manager
GET /platform/api/processes
Get running processes list.
Request Headers
Response
200 OKEmpty if there is no running process found.
```json
[ { "pid": 1, "name": "systemd", "numThreads": 1, "memUsage": 9187328, "cpuPercent": 0.0010817868420981225, "username": "root", "elapsedTime": 1191547, "path": "/lib/systemd/systemd", "cmdline": "/sbin/init splash" }, { "pid": 2, "name": "kthreadd", "numThreads": 1, "memUsage": 0, "cpuPercent": 0.000013427920447930759, "username": "root", "elapsedTime": 1191547 }, ... ]
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
GET /platform/api/processes (SSE)
Get running processes list via Server-Sent Events (SSE)
EventStream
event: message
data: [{"pid":4,"name":"System","numThreads":169,"memUsage":20480,"cpuPercent":6,"username":"NT AUTHORITY\\SYSTEM","elapsedTime":876611},{"pid":56,"ppid":4,"name":"Secure System","memUsage":23273472,"cpuPercent":0,"username":"NT AUTHORITY\\SYSTEM","elapsedTime":876613},{"pid":100,"ppid":4,"name":"Registry","numThreads":4,"memUsage":208896,"cpuPercent":0,"username":"NT AUTHORITY\\SYSTEM","elapsedTime":876612},{"pid":416,"ppid":4,"name":"smss.exe","numThreads":2,"memUsage":98304,"cpuPercent":0,"username":"NT AUTHORITY\\SYSTEM","elapsedTime":876611},{"pid":604,"ppid":572,"name":"csrss.exe","numThreads":12,"memUsage":671744,"cpuPercent":0,"username":"NT AUTHORITY\\SYSTEM","elapsedTime":876609}, ...]
DELETE /platform/api/processes/:pid
Kill the selected process (selected by pid)
Request Headers
Response
Response
400 Bad RequestThe :pid is not a valid value.
"errors": {
"Processes": "Invalid PID"
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
"errors": {
"Processes": ""
Remote Control
POST /platform/api/control/reboot
Restart the target computer. It requires Admin permission.
Request Headers
Response
200 OK -
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
403 ForbiddenThe login user has no permission to reboot the target computer.
Response
"errors": {
"Control": ""
POST /platform/api/control/shutdown
Shut down the target computer. It requires Admin permission.
Request Headers
Response
200 OK -
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
403 ForbiddenThe login user has no permission to shut down the target computer.
Response
"errors": {
"Control": ""
GET /platform/api/control/display
Check whether the target computer supports the display on/off feature. (since rest-server 1.0.1)
Request Headers
Response
204 No ContentThe target computer supports the display on/off feature.
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
404 Not FoundThe target computer does not support the display on/off feature.
PUT /platform/api/control/display
Turn the display of the target computer on or off. (since rest-server 1.0.1)
Request Headers
Request Body
"status": "on" | "off"
Response
200 OK -
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
"errors": {
"Control": ""
Remote Desktop
POST /platform/api/rdesk/config
Gets the remote desktop connection information via WebSocket.
Request Headers
- Include a valid JWT token obtained by logging in with the OS or "admin" account.
Response Codes
200 OK(Success)- Response body contains:
id(string): The unique identifier (UUID) for the remote desktop connection.os(string, optional): Operating system of the remote desktop (e.g., "windows", "linux").password(string): The password for the remote desktop connection.
"id": "5b306b78-d720-4dac-984e-a1f1ca9cd963",
"os": "windows",
"password": "EmzE4lo0"
} - Response body contains:
401 Unauthorized(Authentication failure){
"Code": 401,
"Message": ""
422 Unprocessable Entity(Invalid request){
"message": ""
GET wss://[host:port]/platform/api/rdesk/:id
Opens a WebSocket connection to communicate with the VNC server for the specified remote desktop.
Request Parameters
:id(string): The unique identifier (UUID) obtained from the response body of thePOST /platform/api/rdesk/configendpoint. This ID identifies the specific remote desktop connection.
Request Headers
Message Description
The WebSocket connection uses a binary message format to proxy data between the client and the VNC server. The specific format of these messages depends on the VNC protocol version used by the server.
- Consult the VNC protocol specifications (https://tools.ietf.org/html/rfc6143) for detailed information about message structure and data types.
Client-Side Considerations
- Utilize the noVNC client-side library (https://github.com/novnc) to establish the WebSocket connection and handle binary VNC message communication.
- Refer to the noVNC documentation for specific integration and usage instructions.
Events
GET /platform/api/events (SSE)
Get all available Server-Sent Events (SSE), including the following events (event type).
- diskdrives
- hwmon
- netifaces
- processes
- pwrstatus
- snmptrap
- systemperf
EventStream
event:
data:
Example
Login with your OS account to get the JWT token (
tokenfield from the response body). -
addEventListener
const eventSource = new EventSource(`/platform/api/ events?token=`, { withCredentials: true });
eventSource.addEventListener(, (event) => {
const data = JSON.parse(event.data);
// process your data
ETP
GET /platform/api/etp/devicedata
Get ETP device data.
Request Headers
Response
200 OK{
"modelName": "XXXXX",
"serialNumber": "Default string",
"boardVersion": "Default string",
"uuid": "00020003-0004-0005-0006-000700080009",
"version": ""
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
204 No ContentNot supported or no available data.
GET /platform/api/etp/userdata
Get ETP user's data.
Request Headers
Response
200 OK{
"data": {
"userSpace1": "",
"userSpace2": ""
"locked": true | false
Response
"errors": {
"ETP": ""
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
"errors": {
"ETP": ""
GET /platform/api/etp/userdata/lockstatus
Get ETP user data area lockstatus.
Request Headers
Response
200 OK{
Response
"errors": {
"ETP": ""
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
"errors": {
"ETP": ""
PUT /platform/api/etp/userdata
Set ETP user's data.
Request Headers
Request Body
The maximum length of userSpace1 and userSpace2 is 128 bytes. (RAW data)
"userSpace1": "",
"userSpace2": ""
Response
200 OK{
"userSpace1": "",
"userSpace2": ""
Response
"errors": {
"ETP": ""
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
404 Not FoundNot supported.
"errors": {
"ETP": ""
Response
"errors": {
"validator": ""
}The
userSpace1oruserSpace2raw data length is out of range (128 bytes).{
"errors": {
"ETP": "The maximum length of UserSpace1 is 128"
PUT /platform/api/etp/userdata/lockstatus
Lock or unlock the ETP user's data area.
Request Headers
Request Body
The maximum length of password is 8 byre.
"locked": true | false,
"password": ""
Response
200 OK{
"locked": true | false, // same as request body
Response
"errors": {
"ETP": ""
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
"errors": {
"ETP": ""
Response
"errors": {
"validator": ""
}The
passwordlength is out of range (1~8 bytes).{
"errors": {
"ETP": ""
EdgeHub
GET /edgehub/api/ping
Response
200 OK-
Body
pong
GET /edgehub/api/agentinfo
Get the agent information. (since v0.15.1)
Response
Body
"version":"v0.15.1"
GET /edgehub/api/macaddr
Get MAC address for device registration.
Request Headers
Response
200 OK"XX:XX:XX:XX:XX:XX" -
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
404 Not FoundNo available data.
Response
"message": ""
GET /edgehub/api/connection
Get connection status.
Request Headers
Response
200 OK{
"enabled": true | false,
"status": "connected | disconnected",
"certRevoked": true | false, // since 1.2.0
"stormDetected": true | false // since 1.3.1
}certRevoked: indicates whether the certificates are revoked or notstormDetected: indicates whether there is a connection storm -
Response
401 Unauthorized{
"Code": 401,
"Message": ""
POST /edgehub/api/connection
Enable or Disable to the device connection.
Request Headers
Request Body
conncfgis optional.If the
opis "connect" and theconncfghas been provided, it will set the connection setting first, then enable the connection to the cloud; if theconncfgis not provided, it will enable the connection only.If the
opis "disconnect", it will disable the cloud connection.conncfgwill be ignored.{
"op": "connect | disconnect",
"conncfg": {
"username": "",
"password": "",
"mqttHost": "",
"mqttPort": 1883,
"enableTLS": true | false,
"overWebSocket": true | false,
"connectionString": "", // optional
"mac": "AABBCCDDEEFF", // optional,
"uuid": "123e4567-e89b-12d3-a456-426614174000", // optional
"deviceon": { // optional (since edgehub-agent 1.0.1)
"dccsUrl": "",
"iotKey": ""
}or
"conncfg": {
// (since edgehub-agent 1.1.0)
"deviceTokenCredential": "",
"skipCertVerify": true | false,
"dccsUrl": "",
"iotKey": ""
Response
200 OK -
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
Response
"message": ""
GET /edgehub/api/conncfg
Get the current device connection setting.
Request Headers
Response
200 OK{
"username": "",
"password": "",
"mqttHost": "",
"mqttPort": 1883,
"uuid": "123e4567-e89b-12d3-a456-426614174000", // optional,
"caCerts": ["", ...],
"iothubKey": "",
"iothubCert": "",
"mqttKey": "",
"mqttCert": ""
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
Response
"message": ""
POST /edgehub/api/conncfg
Set the connection setting.
Request Headers
Request Body
"username": "",
"password": "",
"mqttHost": "",
"mqttPort": 1883,
"dccsUrl": "",
"iotKey": ""
}or
"dccsUrl": "",
"iotKey": ""
"caCerts": ["", ...], // optional
Response
200 OK{
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
Response
"message": ""
DELETE /edgehub/api/conncfg
Clear the current device connection setting.
Request Headers
Response
200 OK -
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
"message": ""
GET /edgehub/api/profile
Get the EdgeHub function profile which contains the agent versions and function support status. It's will be sent to the cloud via MQTT topic Advantech//update/platform/profile (since edgehub-agent 1.0.1)
Request Headers
Response
200 OK{
"agent:version:auth-server": "v1.9.1",
"agent:version:edgehub-agent": "v1.0.2",
"agent:version:edgex-helper": "v0.6.1",
"agent:version:portal-service": "v1.0.1",
"agent:version:rest-server": "v1.0.1",
"apphub": 2,
"host:display:count": 1,
"host:info": 1,
"hwmon": 1,
"ibmc": 0,
"model:name": "UNO-2484G-673xAE",
"networking:interfaces": 5,
"os": "windows",
"os:arch": "x86_64",
"os:description": "Microsoft Windows 10 Enterprise LTSC 2019",
"perif:brightness": 0,
"perif:disk": 1,
"perif:gpio:all": 0,
"perif:gpio:count": 0,
"perif:led": 0,
"perif:wdt": 1,
"perif:wdt:enabled": false,
"perif:wdt:timeoutInSeconds": 60,
"perif:wdt:timeoutMaxInSeconds": 255,
"perif:wdt:timeoutMinInSeconds": 10,
"perif:wdt:type": "EC",
"processes": 194,
"service:list": 1,
"system:ip": "172.16.12.123",
"system:mac": "00:0b:ab:12:34:56",
"systemperf": 1
Response
401 Unauthorized{
"Code": 401,
"Message": ""
POST /edgehub/api/data
Send tag data to the cloud. (since edgehub-agent 1.0.1)
Request Headers
Request Body
"string_data": "abcdefg...",
"number_data": 12345,
"bool_data": true,
Response
201 CreatedThe data has been sent successfully.
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
400 Bad RequsetThe request data is empty, invalid format, or incorrect value.
"message": ""
Response
"message": ""
GET /edgehub/api/apphub/status
Get the AppHub service running status. (since edgehub-agent 1.0.1)
Request Headers
Response
200 OK{
"status": "running",
}Note: The possible
statusvalues are "unknown or not available", "running", "stopped", "**unknown status: **" -
Response
404 Not FoundIt indicates there is no AppHub service installed.
Response
401 Unauthorized{
"Code": 401,
"Message": ""
PUT /edgehub/api/apphub/service
Control the AppHub service status. (since edgehub-agent 1.0.1)
Request Headers
Request Body
Response
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
"message": ""
PUT /edgehub/api/apphub/log/config
Set up the AppHub log configuration. (since edgehub-agent 1.0.1)
Request Headers
Request Body
Setup
logFileandlogLevelsimultaneously.{
"logFile": true | false,
"logLevel": "error" | "info"
Setup
logFileonly.{
Setup
logLevelonly.{
Response
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
"message": ""
Response
"message": ""
GET /edgehub/api/edgebus/status
Get the EdgeBus (Embedded Broker) running status. (since edgehub-agent 1.0.1)
Request Headers
Response
200 OK{
"enabled": true,
"mqttBrokerStatus": {
"version": "2.2.8",
"started": 1683597812,
"time": 1683786741,
"uptime": 188929,
"bytes_received": 1107413,
"bytes_sent": 1090102,
"clients_connected": 2,
"clients_disconnected": 0,
"clients_maximum": 2,
"clients_total": 2,
"messages_received": 10437,
"messages_sent": 10489,
"retained": 0,
"inflight": 0,
"inflight_dropped": 0,
"subscriptions": 3,
"packets_received": 23949,
"packets_sent": 24001,
"memory_alloc": 7553024,
"threads": 75
"clientStatus": "connected"
Response
404 Not FoundIt indicates there is no EdgeBus service support.
Response
401 Unauthorized{
"Code": 401,
"Message": ""
PUT /edgehub/api/edgebus/config
Set up the EdgeBus (Embedded Broker) configuration. (since edgehub-agent 1.0.1)
Request Headers
Request Body
Enable or Disable the EdgeBus (Embedded Broker).
"enabled": false
Response
200 OKSame as the request body.
"enabled": false
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
"message": ""
POST /edgehub/api/pem/temp
Upload a PEM file and encode it to a base64 string if the file is valid. (since edgehub-agent 1.1.0)
Request Headers
Request Body
The request body must be multipart/form-data with a field name
fileand the value is the File containing the PEM data to upload. -
Response
200 OKThe
typeis the PEM file type, such asCERTIFICATE,PRIVATE KEY. Thedatais the base64-encoded PEM file content.{
"type": "CERTIFICATE",
"data": ""
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
"message": ""
PUT /edgehub/api/bootstrap/config
Set up the EdgeHub Mass Deployment configuration. (since edgehub-agent 1.5.1, edgehub-suite 1.4.0)
Request Headers
Log in with the OS or the "admin" account to get a JWT token (
Request Body
The request body should contain the tenant access token obtained from the EdgeHub Mass Deployment tab.
"tenantToken": "eyJ0eXA..."
}tenantToken: The access token for the specific tenant you want to configure for mass deployment.
Response
201 CreatedThe configuration has been successfully applied.
Response
401 Unauthorized{
"Code": 401,
"Message": ""
Response
422 Unprocessable EntityThe request could not be processed due to invalid configuration data. The response will include a JSON object with:
message: A specific error message detailing the configuration error.
"message": ""
