跳至主要内容
This chapter will introduce various settings for the interactive signage server, including accessing the configuration interface, environment settings, web server settings, data server settings, message transmission service settings, relay server settings, backup and restore settings, and applying server settings.
  1. Environment Settings: This section allows you to configure the basic environment settings of the server and access essential information such as software version, Wake-on-LAN broadcast IP, and Admin password reset.
  2. Web Server Settings (Apache): This feature enables you to configure and obtain information about the Apache web server, such as adjusting server settings, enabling SSL, and setting up virtual hosts.
  3. Data Server Settings (PostgreSQL): This feature allows you to configure and obtain information about the PostgreSQL database server, including service status and communication ports.
  4. Message Transmission Service Settings (Mosquitto): This feature enables you to configure and obtain information about the Mosquitto message broker server, including service status and communication ports.
  5. Relay Server Settings: This setting allows you to configure relay servers, including setting up relay server ID, URL, and ports.
  6. Backup and Restore Settings: This setting allows you to configure backup and restore functionality, such as specifying backup paths and backup/restore settings.
  7. Apply Server Settings: This setting allows you to apply the changes made so that the server can run with the new settings.
Is this helpful?
