IEC104
一、Driver support start version number:
二、Quick Connection
1.Add Device
- DataCenter--->I/O Tag--->TCP--->Right Click:Add Device
2.Configure the device
- Select Device Type:IEC 60870-5-104--->Fill in the IEC104 server IP and port number: such as 172.21.67.56 and 2404--->click "Apply"
3.Add tag(s)
4.Download project,completed the quick configuration of IEC104.
三、Detailed configuration instructions
1.Detailed configuration interface instructions
Name: Fill in as desired.
Device Type: Select IEC 60870-5-104.
IP/Domain Name: The IP address of the IEC104 server.
Port Number: The port number of the IEC104 server.
t1:t2:t3:k:w:OA:DA:ST:
- t1:1~255 seconds, Refer to the IEC104 protocol for specific requirements.
- t2:1~600 seconds, Refer to the IEC104 protocol for specific requirements.
- t3:1~600 seconds, Refer to the IEC104 protocol for specific requirements.
- k: 1~32767, Refer to the IEC104 protocol for specific requirements.
- w: 1~32767, Refer to the IEC104 protocol for specific requirements.
- OA:Master Address,Refer to the IEC104 protocol for specific requirements.
- DA:Slave public address.
- ST:Scan time. 1 ~3000 seconds.
Detailed description of tag point configuration
There are three types of Tag.
A. Read Only Tag Format: R:Read Address / Read Data Type / Read Command
Example: R:402 / M_BO_NA_1 / nB. Write Only Tag Format: W:Write Address / Write Command
Example: W:2300 / C_RC_NA_1 Note: Always show value 0 for this kind of tagC. Read And Write Tag Format: R:Read Address / Read Data Type / Read Command / W:Write Address / Write Command Example: R:400 / M_BO_NA_1 / n / W:2400 / n
Note: Add /SE after Write Command to change “Direct Execute” to “Select and Execute”
- Read And Write Tag Format: R:Read Address / Read Data Type / Read Command / W:Write Address / Write Command / SE Example: R:100 / M_SP_NA_1 / n / W:2100 / n / SE
- Write Only Tag Format: W:Write Address / Write Command / SE Example: W:2100 / C_SC_NA_1 / SE
