Data Objects Management
Overview
To provide clear and focused documentation, the container workflow has been divided into three dedicated articles.
This article specifically covers Data Objects Management, which focuses on managing telemetry data, defining transfer functions, and setting up alert rules.
Basic Operations
Basic API URL: https://{domain}/{tenantPath}/{srp}
| Operation | API | Description |
| Create transfer function | POST {Basic API URL}/api/v1/devices/{deviceId}/inputs/data-objects/transfer-functions | Create a new transfer function |
| List transfer functions | GET {Basic API URL}/api/v1/devices/{deviceId}/inputs/data-objects/transfer-functions | Get device transfer functions |
| Update transfer function | PATCH {Basic API URL}/api/v1/devices/{deviceId}/inputs/data-objects/transfer-functions/{transferFunctionId} | Update the expression of a function |
| Delete transfer function | DELETE {Basic API URL}/api/v1/devices/{deviceId}/inputs/data-objects/transfer-functions/{transferFunctionId} | Delete a transfer function by its ID. This is a soft delete operation. |
| Create alert rule | POST {Basic API URL}/api/v1/devices/{deviceId}/inputs/data-objects/alert-rules | Create rule with trigger/reset conditions, delay, and notification settings |
| List alert rules | GET {Basic API URL}/api/v1/devices/{deviceId}/inputs/data-objects/alert-rules | Get device alert rules |
| Update alert rule | PATCH {Basic API URL}/api/v1/devices/{deviceId}/inputs/data-objects/alert-rules/{alertRuleId} | Update conditions and notification settings |
| Delete alert rule | DELETE {Basic API URL}/api/v1/devices/{deviceId}/inputs/data-objects/alert-rules/{alertRuleId} | Delete an alert rule |
Constraints & Limitations
General
- API access requires authentication with a valid token
- Device must be online and registered to create tunnel sessions
Transfer Functions: Create
typeis required, must be Expression.outputDataObjectNameis required, output data object name for the transformed value. Must be unique for the device. Accepted formats: camelCase, snake_case, or single word.expressionis required, mathematical expression for transformation. Supports basic arithmetic operators (+, -, *, /, %). The variable name will be automatically extracted.
Transfer Functions: Update
isEnabledenable or disable the transfer function. Disabling a function will stop producing the derived data object but will not delete the function definition.
Alert Rules: Create
Advanced Features
Transfer Function
| Get transfer function by ID | GET {Basic API URL}/api/v1/devices/{deviceId}/inputs/data-objects/transfer-functions/{transferFunctionId} | Retrieve details of a specific function |
| Update transfer function status | PATCH {Basic API URL}/api/v1/devices/{deviceId}/inputs/data-objects/transfer-functions/{transferFunctionId}/status | Enable or disable a transfer function |
Alert Rule
| Get alert rule by ID | GET {Basic API URL}/api/v1/devices/{deviceId}/inputs/data-objects/alert-rules/{alertRuleId} | Retrieve details of a specific alert rule |
| Update alert rule status | PUT {Basic API URL}/api/v1/devices/{deviceId}/inputs/data-objects/alert-rules/{alertRuleId}/status | Enable or disable an alert rule |
Last updated on Apr-8, 2026 | Version 1.0.0
