Batch Tasks Management
Overview
The Batch Tasks Management module in WEDA allows users to create, manage, and execute batch tasks for automating repetitive operations and processing large volumes of data efficiently. This module provides a structured way to define tasks, schedule their execution, and monitor their performance through the WEDA Core API.
Basic Operations
Basic API URL: https://{domain}/{tenantPath}/{srp}
| Operation | API | Description |
| Create Task | POST {Basic API URL}/api/v1/orgs/{orgId}/tasks | Create a new task under an organization |
| List Tasks | GET {Basic API URL}/api/v1/orgs/{orgId}/tasks | Get list of tasks in a specific organization |
| Update Task | PUT {Basic API URL}/api/v1/orgs/{orgId}/tasks/{taskId} | Update task's details in an organization |
| Remove Task | DELETE {Basic API URL}/api/v1/orgs/{orgId}/tasks/{taskId} | Remove task from an organization |
| Create Batch | POST {Basic API URL}/api/v1/orgs/{orgId}/batches | Create a new batch under an organization |
| List Batches | GET {Basic API URL}/api/v1/orgs/{orgId}/batches | Get list of batches in an organization |
| Update Batch | PUT {Basic API URL}/api/v1/orgs/{orgId}/batches/{batchId} | Update batch's details in an organization |
| Remove Batch | DELETE {Basic API URL}/api/v1/orgs/{orgId}/batches/{batchId} | Remove batch from an organization |
Constraints & Limitations
General
- API access requires authentication with a valid token
- Organization must exist
Task: Update
cmdis the command that will be executed.payloadis the variables in the payload.
Task: Delete
- The task can only be deleted if it is not linked to any batch.
Batch: Create
cronExpressionis required and must be a valid cron expression.isEnabledis required, whether the batch is enabled.runOnStartupis required, whether the batch should run on startup.actionsis required, which defines the tasks to be executed in the batch.
Batch: Delete
- Only batches with
isEnabledset to false can be deleted.
Advanced Features
Task
| Get Task Details | GET {Basic API URL}/api/v1/orgs/{orgId}/tasks/{taskId} | Get details of a specific task in an organization |
Batch
| Get Batch Details | GET {Basic API URL}/api/v1/orgs/{orgId}/batches/{batchId} | Get details of a specific batch in an organization |
| Get Task Results | GET {Basic API URL}/api/v1/orgs/{orgId}/batches/{batchId}/results | Get execution history of a specific task in an organization |
| Update Batch Actions | PUT {Basic API URL}/api/v1/orgs/{orgId}/batches/{batchId} | Update the actions of a specific batch in an organization |
| Trigger Batch Execution | POST {Basic API URL}api/v1/orgs/{orgId}/batches/{batchId}:start | Trigger the execution of a specific batch in an organization |
| Get Triggered Batches | GET {Basic API URL}/api/v1/orgs/{orgId}/batches/{batchId}/triggers | Retrieve the list of batch trigger IDs for a specific batch |
| Enable/Disable Batch | PUT {Basic API URL}/api/v1/orgs/{orgId}/batches/{batchId}/status | Enable or disable a specific batch in an organization |
| Get Device Batch | GET {Basic API URL}/api/v1/orgs/{orgId}/batches/{batchId}/devices | Retrieve the list of device IDs associated with a specific batch |
Last updated on Apr-8, 2026 | Version 1.0.0
