Tunnel Management
Overview
WEDA Tunnel Management lets a customer reach any service running on any registered edge device - SSH, RDP, VNC, web consoles, MQTT brokers - from one console, in seconds, without ever opening a port on the device's network.
Basic Operations
Basic API URL: https://{domain}/{tenantPath}/{srp}
OperationAPIDescription
Creates a tunnel sessionPOST {Basic API URL}/api/v1/devices/{deviceId}/tunnels/sessionsCreate and start a new tunnel session for a specific device
Get tunnel sessionsGET {Basic API URL}/api/v1/devices/{deviceId}/tunnels/sessionsGet active tunnel sessions of a specific device
Get tunnel session detailsGET {Basic API URL}/api/v1/devices/{deviceId}/tunnels/sessions/{tunnelSessionId}Get details of a specific tunnel session
Terminate a tunnel sessionPOST {Basic API URL}/api/v1/devices/{deviceId}/tunnels/sessions/{tunnelSessionId}Terminate a specific tunnel session
Constraints & Limitations
General
  • API access requires authentication with a valid token
  • Device must be online and registered to create tunnel sessions
Create
  • serviceType is required, must be one of ssh, http, https, vnc, rdp, mqtt, default is ssh.
  • applicationHost is required, must be a valid IP address or domain name.
  • applicationPort is required, must be an integer between 0 and 65535.
Delete
  • Only active tunnel sessions can be terminated. Sessions that are already terminated or failed cannot be terminated again.
  • graceful termination is recommended to allow existing connections to close cleanly. Forceful termination may result in abrupt disconnections for users connected through the tunnel.
  • forceTimeout should be set to a reasonable value (e.g., 30 seconds) to allow for graceful shutdown before forcing closure. Setting it too low may not give enough time for connections to close properly, while setting it too high may delay the termination process unnecessarily.
Last updated on Apr-8, 2026 | Version 1.0.0
