2.2 Plant Overview​
This page provides a centralized display of the energy station's 3D process flow and key efficiency metrics, including alarm information, system efficiency ratio, load percentage, etc.
Plant Overview
Key Notes:
  1. Rounding Rules: For values displayed in the red-framed panel area when the unit is kWh (base unit), the system will display rounded integers only, while converted units may display up to two decimal places.
  2. Decimal Display: All data on this page shows a maximum of two decimal places. Trailing zeros are omitted.
  3. Efficiency Dashboard Thresholds: The efficiency dashboard thresholds are derived from the energy efficiency thresholds configured in the [Cooling energy efficiency indicators] module under [Plant Info].
  4. Total Power Consumption, Total Energy Savings, Total Runtime and Cumulative Energy Savings Ratio: These metrics are calculated from the official operation date, set in the [Start date] field under [Plant Info].
  5. Total Energy Savings Calculation:
    Total Energy Savings = (Cooling Capacity / Pre-Retrofit Efficiency) – Actual Total Power Consumption
    The cooling capacity is calculated from the official operation date. The pre-retrofit efficiency is configured in the [Plant EER before renovation] field under [Plant Info].
  6. Cumulative Savings Ratio Calculation:
    Cumulative Savings Ratio = Total Energy Savings / (Cooling Capacity / Pre-Retrofit Efficiency)
    = (Cooling Capacity / Pre-Retrofit Efficiency – Actual Total Power Consumption) / (Cooling Capacity / Pre-Retrofit Efficiency)
    = 1 – (Actual Total Power Consumption × Pre-Retrofit Efficiency) / Cooling Capacity
  7. Design Cooling Load: Configured in the [Design Cooling Load] field under [Plant Info].
System Efficiency Dashboard
Energy Metrics
2.2.1 Equipment Data Analysis​
Note: The data analysis display format for equipment may vary depending on project requirements and is for reference only.
Click on key equipment in the bottom-left process diagram to view detailed information.
Default diagram supports the following clickable key equipment:
Energy Station TypeKey Equipment
Water-Cooled StationChillers, Cooling Towers, Cooling Pumps, Chilled Water Pumps
Ground Source Heat Pump (GSHP) StationGSHP Units, Ground Source Side Pumps, AC Side Pumps
Switch between tabs to query historical equipment data.
Equipment Data Analysis - Parameters
Equipment Data Analysis - Trend
On this page ...
Is this helpful?
