跳至主要内容
WEDA Core v1.2.2
Release date: November 26, 2026
A maintenance release for WEDA Core v1.2. WEDA Console now covers JavaScript Analyzers and AI Model deployment options, which were previously available only through the API. This release also fixes device management, telemetry and Console issues. Two changes affect API behavior; review them before updating integrations.
What's New​
The following features already existed in the WEDA API. This release adds them to WEDA Console.
ModuleDetails
WEDA Console
  • JavaScript Analyzers: Create and edit JavaScript Analyzers on a device's Analyzers tab. See JavaScript Analyzer.
  • AI Model deployment options: When you deploy an Edition from the AI Model or from a device, set the pre-check, the validation after download and whether to restart containers after deployment. See Deploy an AI Model.
Behavior Changes​
ModuleDetails
Device Management
  • Deleting a WEDA Node also deletes its SubNodes and clears their DataStreams. Previously, the SubNodes and their DataStreams remained. If the deletion fails, nothing is deleted. When you register the WEDA Node again, its SubNodes are restored after it reports its capabilities. See Delete a Device.
  • Update device telemetry settings returns 409 Conflict with deviceCapabilityNotReported when a WEDA Node v1.2 device has not reported its capabilities yet. No configuration is sent. Retry after the device is online and has reported its capabilities.
WEDA Console
  • The AI Model list shows the status In progress, Uploaded, Interrupted or Error, and no longer shows the Edition count.
Fixed​
ModuleDetails
Device Management
  • Updating telemetry configuration no longer fails with 400 on a device upgraded from an earlier WEDA Node version. Sensors that the device no longer reports in its capabilities are removed from the stored configuration when you update it. Sensors named in your request are still validated.
  • Commands invoked on a SubNode with commands:invoke now time out on the device after timeoutSeconds. Previously, the device received the timeout in the wrong unit and did not time out as expected.
Telemetry
  • WEDA Core no longer stops receiving telemetry after a restart in an environment with a large number of DataStreams. Previously, loading DataStream information at startup could time out, and no new telemetry was processed.
Data Analyzer
  • With a large number of Analyzers, WEDA Core could fail to load them at startup. They now load correctly.
WEDA Console
  • Container Registries: Adding a registry shows a clear validation message for an invalid name or URL instead of a generic error, trims trailing spaces from the URL and no longer creates a duplicate when Add is selected twice. The list refreshes correctly after you switch Org or delete the last item on a page.
  • Container Stacks: A failed list or Deployments load is reported once and can be retried, instead of showing a success message or repeating an error every 5 seconds. Long names and details wrap instead of overflowing.
  • AI Models: A cancelled deployment record can be deleted. Upload actions show the correct state after you leave the page and return.
  • MQTT Brokers: Editing a broker no longer requires you to enter the username and password again. To replace the saved credentials, select Change Credentials. Saved credentials are never displayed. See DataStream Bridge.
This release also includes other bug fixes.
Last updated on Nov-26, 2026 | Version 1.2.2
On this page ...
Is this helpful?
