📄️MUI Boilerplate OverviewPrepare access, run the WEDA frontend locally, and begin building your own management application.📄️Customize Your ApplicationFind the right place to change the UI, follow the feature layers, and verify your customization.📄️Authentication IntegrationConfigure local PKCE sign-in and understand Portal login, runtime configuration, and routing for deployment.
