WEDA Core Release Notes (v0.1 Alpha)
Release Date: December 05, 2025
This is the Initial Release (v0.1) of WEDA Core. All features listed below are currently in Alpha stage and are subject to change as we refine the platform.
References
Note: The following links are the primary sources for documentation and API definitions.
WEDA Core Technical Documentation:
https://learn.advantech.com/weda/docs/weda_core/what_is_weda_core
Scope: What's WEDA Core, How-To-Use, Fundamentals, Release Notes -
WEDA Core API Documentation:
https://learn.advantech.com/weda/api/weda-api
Scope: Full API reference including endpoints, parameters, and error codes.
Alpha Features
Identity & Access
Organization Management
- Feature: Supports creating, updating, and deleting organizations, as well as querying hierarchies.
- Reference:
create-a-new-organization,delete-an-organization,get-a-specific-organization-by-id,get-children-organizations-up-to-certain-depth,get-organizations-root-or-sub-orgs,get-parent-organizations-up-to-certain-depth,update-an-existing-organization
User & Role Management
- Feature: Enables user authentication (token generation), adding users to organizations, assigning roles, and managing access.
- Reference:
add-an-existing-user-to-an-organization,create-jwt-access-token,get-a-paginated-list-of-users,get-organization-user-by-composite-key,get-users-by-organization-id,get-users-roles-across-organizations,update-organization-user-by-composite-key
Devices
Lifecycle Management
- Feature: Comprehensive capabilities for device creation, updates, deletion, and activation.
- Reference:
activate-device,create-device,delete-device,get-device-auth-info,get-devices,get-devices-of-one-organization,get-paginated-of-all-devices,list-device-capabilities,update-device
Organization Linking
- Feature: Allows linking devices to organizations and managing these associations.
- Reference:
link-or-create-one-device-to-one-organization,remove-linkage-between-device-and-organization
Metadata Management
- Feature: Supports managing custom device attributes and capabilities.
- Reference:
add-or-update-multiple-custom-info-entries,delete-all-custom-info-of-a-device,get-custom-info-of-a-device,update-a-single-custom-info-entry
Data Objects
Alerting
- Feature: Full lifecycle management for alert rules.
- Reference:
create-alert-rule,delete-alert-rule,get-alert-rule-by-id,get-alert-rules-with-pagination,update-alert-rule,update-alert-rule-status
Configuration & Telemetry
- Feature: APIs for device config updates and telemetry data querying.
- Reference:
get-config,get-device-latest-telemetry-snapshot,get-paginated-data-object-channel-results-of-time-range,get-paginated-telemetry-results-of-time-range,get-state,update-config
Batch Tasks
Batch & Task Lifecycle
- Feature: Management of batch jobs and individual tasks.
- Reference:
create-a-new-batch-under-org,create-a-new-task-under-an-organization,delete-a-batch-safely,delete-a-task,enable-or-disable-an-existing-batch,get-a-batch-by-id,get-a-paginated-list-of-tasks-by-organization,get-a-task-by-id,get-batch-list-of-an-org,get-results-of-a-batch,update-a-task,update-an-existing-batch,update-only-actions-of-a-batch
Execution
- Feature: Triggering executions and inspecting associations.
- Reference:
get-devices-associated-with-a-batch,get-trigger-list-for-a-batch,trigger-a-batch-execution
Container Stacks
- Stack Management
- Feature: APIs for container stack definitions and revision control.
- Reference:
compare-specified-revisions-of-container-stack,create-container-stack,delete-specified-container-stack,delete-specifiedrevision-of-container-stack,get-all-revision-of-container-stack,get-container-stacks,get-latest-revision-of-container-stack,get-specified-revision-of-a-container-stack,update-the-latest-revision-of-a-container-stack
