跳至主要内容
System-Managed DataStreams
Data Engine Pipeline
Device → DataStream (managedBy: System) → Analyzer (optional) → DataStream (managedBy: User) → Alert Policy / Bridge
Overview​
When a device connects, WEDA Node reports its sensor capability and WEDA Core automatically syncs each reported sensor into a DataStream with managedBy: System. There is no separate "Data Source" entity or endpoint to query first — the device's sensor list and its DataStreams are the same lookup: GET .../data-streams.
A System-managed DataStream is:
  • Read-only for identity/lineage — dataStreamName, dataType, and dataSource come from the device and cannot be changed via the API
  • Editable for display — displayName, description, unitDisplay, and recordToDataLake can be updated (PATCH)
  • Traceable to its origin — dataSource.type is WedaNode or WedaSubNode; dataSource.sourceEntityId is the underlying sensor resource ID reported by the device
Discover a Device's DataStreams​
OperationAPIDescription
List DataStreamsGET /api/v1/orgs/{orgId}/devices/{deviceId}/data-streamsAll DataStreams for a device, including their dataSource lineage
Get DataStreamGET /api/v1/orgs/{orgId}/devices/{deviceId}/data-streams/{dataStreamId}One DataStream by ID
Filter the list by managedBy=System to see only device-originated streams, or managedBy=User to see streams created directly (e.g. Analyzer outputs).
System Agent Metric Types​
For a device running WEDA Node, the built-in System Agent reports hardware and system metrics. WEDA Core then auto-syncs the corresponding DataStreams. The following names are examples; call GET /api/v1/orgs/{orgId}/devices/{deviceId}/data-streams to discover the DataStreams exposed by a specific device and configuration.
System Resources (all platforms)​
MetricTypeExample DataStreamsUnit
cpucpu_usage, cpu_load1, cpu_load5, cpu_load15, cpu_context_switches%, count
memorymemory_total, memory_available, memory_used, memory_usage_percentbytes, %
diskdisk_usage_percent, disk_total, disk_available, disk_reads_completed%, bytes, count
networknetwork_bytes_sent, network_bytes_received, network_errors_inbytes, count
systemsystem_time, system_boot_time, system_procs_runningUnix ms, count
gpugpu_utilization%
disk requires a MountPoint parameter (e.g. / or C:\). network requires an Interface parameter (e.g. eth0).
Hardware Sensors (Advantech industrial PCs)​
Requires the Advantech SUSI driver. Available on Advantech industrial computers by default.
MetricTypeWhat it reports
hwinfoMotherboard name, BIOS revision, driver version, EC revision
temperatureAll temperature sensors as a dictionary (key = sensor name e.g. CPU, value = °C)
voltageAll voltage rails as a dictionary (key = rail name e.g. +3.3V, value = V)
fanspeedAll fan speeds as a dictionary (key = fan name e.g. CPU_Fan, value = RPM)
Hardware Functionality (Advantech industrial PCs)​
gpioGPIO pin states
watchdogTimer IDs, capability, and current configuration
thermalprotectionProtection zones, source sensor, event type, and shutdown temperature
備註
If the SUSI driver is not installed, hardware-specific metrics are silently skipped — system resource metrics continue collecting normally.
Other device types
SubNode devices expose different DataStreams based on their device definition. The metric types above apply only to WEDA Node's built-in System Agent. Call GET /api/v1/orgs/{orgId}/devices/{deviceId}/data-streams to discover the actual DataStreams a specific device exposes.
Constraints​
  • System-managed DataStreams cannot be deleted, and only displayName/description/unitDisplay/recordToDataLake can be updated — attempting to change dataStreamName or dataType returns 409
  • A System-managed DataStream becomes available only after WEDA Node reports and syncs the device's capability with WEDA Core
  • A System-managed DataStream's identity is tied to dataSource.sourceEntityId — the sensor's resource ID, assigned by the system and not settable by clients. If the same resource ID is reported again after the device was deleted and re-registered in the same Org, it resolves to the existing DataStream instead of creating a new one, so the stream's history continues. DataStreams are Org-scoped, so this does not carry across Orgs
  • The sensors exposed by a SubNode depend on its device definition
Last updated on Aug-1, 2026 | Version 1.1.1
