跳至主要内容
MD5: 51319f6b641812fb6e8b2291172006d6
Version: Alpha
Test Report:Link
Overview
  • Release Date: 2025/05/21
  • Support Product: EPC-R7300
Comment
Features
ComponentVersion
SOMORIN NX 8G/16G and ORIN Nano 4G/8G
Jetpack version6.2
L4T version36.4.3
Flash Step
Device Connection
Entering Recovery Mode
The device supports two methods to enter recovery mode:
Command Trigger Mode
  1. Connect the Micro USB cable to the Host PC
  2. Run command on Host PC:
    sudo reboot --force forced-recovery
  3. Verify recovery mode by checking if NVIDIA Corp is detected:
    lsusb | grep "NVIDIA Corp"
    Expected output: XXXX:XXXX NVIDIA Corp
Device Trigger Mode
  1. Open the back cover
  2. Connect the Micro USB cable to the Host PC
  3. Press the SW1 button and power on
    SW1 Button
  4. Verify recovery mode by checking if NVIDIA Corp is detected:
Start flash BSP
Run Command on Host PC
  • Extracted BSP image file
$  sudo tar -zxvf epcr7300a1_uj06204_k0515148_nvona_08g_nvme_2025-05-21.tgz
  • Switch Directory
$  cd Linux_for_Tegra
  • To flash QSPI + NVME SSD:
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" --showlogs --network usb0 jetson-orin-nano-devkit-super internal
