Onboard Your Device
This tutorial guides you through onboarding an Advantech edge device to the WEDA framework. The process involves registering your organization and device on WEDA Core (the central management service) and provisioning WEDA Node (the client daemon) on your physical edge hardware.
Prerequisites
  1. Confirm your target edge device meets the system requirements detailed in the Prerequisites & Basics guide.
  2. Download and import the WEDA Postman Collections: 0-WiseSso, 1-Org&ClientCred, 2-Provisioning&Activation, and 3-Telemetry.
  3. Select your active Postman environment and confirm that the required variables (e.g., domain, tenantPath, appPath, login, and password) are filled out.
Workflow Overview
Onboarding is a coordinated sequence of actions between WEDA Core and WEDA Node:
Quick Navigation
  1. Retrieve Access Token
  2. Create an Organization
  3. Retrieve Hardware Metadata
  4. Register the Device
  5. Launch WEDA Node & Verify Connection
  6. Get Device Telemetry Data
1. Retrieve Access Token (WEDA Core)
Before invoking WEDA Core APIs, you must authenticate through the WiseSSO Identity Service to retrieve a Bearer Token.
Postman Collection: 0-WiseSso
Execute the five requests in sequence to establish your identity context. Postman scripts will automatically clear cookies, manage redirects, and extract the accessToken variable.
  1. External Login 302
  • Method: GET
  • URL: {{domain}}/{{tenantPath}}/portal/external-login?returnUrl={{domain}}/{{tenantPath}}/{{appPath}}
  • Description: Initializes the identity federation redirect flow and parses the query parameters to set client_id, tenantId, and redirect_uri environment variables.
  • Result: WEDA Cloud returns 302. External Login
  1. Account Login
  • This step submits your account credentials to authenticate the user with the identity service.
  • Expected result: WEDA Cloud returns 200, accepts the login, and updates the authenticated session context. Account Login
  1. External Login 200
  • This call completes the tenant-aware login return flow and confirms the correct tenant context.
  • Expected result: WEDA Cloud returns 200 with the expected tenant context. External Login 200
  1. Signin Oidc
  • This step uses the authenticated session cookie to perform OIDC (OpenID Connect) sign-in and obtain exchangeable identity tokens.
  • Expected result: WEDA Cloud returns 302 and redirects with the OIDC exchange context. Signin Oidc
  1. WEDA Token
  • This final request exchanges the OIDC result for the WEDA access token used by subsequent API requests.
  • Expected result: WEDA Cloud returns 201 with a valid WEDA access token for subsequent API calls. Access Token
2. Create an Organization (WEDA Core)
Organizations isolate devices, telemetry rules, and containers within a tenant on WEDA Core.
Postman Collection: 1-Org&ClientCred
Execute the following requests to establish your organization space. This collection automatically injects the {{accessToken}} Bearer token into all requests.
  • Org Create: Create a new organization with a unique name.
  • Method: POST
  • URL: {{apibaseurl}}/orgs
  • Payload:
"name": "someOrgName"
  • Description: Creates a unique organization associated with your login account. On success (HTTP 201 Created), Postman extracts the ID and saves it to your environment as org_id.
note
If the organization name already exists, WEDA Cloud returns 409.
Postman org create
Example Request: Curl
curl --location --request POST 'https://{domain}/{tenantPath}/{appPath}/api/v1/orgs' \
--header 'Content-Type: application/json' \
--header 'Authorization: Bearer {access-token}' \
--data '{
"name": "new_org"
Example Response
"name": "new_org",
"orgId": "26ba6f6e-8454-4778-a69a-100d852fdc71",
"parentOrgId": null,
"description": null,
"admins": [
"userId": "019ea502-04c5-7382-b4df-fb31a00fb002",
"orgRole": "admin",
"name": "Alvin Wang"
"dateCreated": "2026-06-09T09:46:19.3412009Z",
"dateModified": null
Key parameters:
  • orgId: The organization ID returned after creating the organization. You will use it again in the device creation step.
    • Example: In the response above, 26ba6f6e-8454-4778-a69a-100d852fdc71 is the orgId.
Other APIs in the 1-Org&ClientCred collection:
3. Retrieve Hardware Metadata (WEDA Node)
To register your edge device, WEDA Core requires its unique MAC address and hardware profile name.
  1. Access your physical edge hardware.
  2. Follow the steps in WEDA Node Activator Installer to download and setup the Activator.
  3. Launch the WEDA Node Activator utility, a shortcut is created on your desktop after setup.
  4. Copy the metadata details from the Activator GUI (see below):
  • Device (deviceId): The device's primary MAC address formatted as a lowercase, continuous string with no colons or hyphens (e.g. cc827f50f406).
  • Model (hwModel): The local system model name retrieved from /etc/board (e.g., MIC-710 or UNO-2484v2).
  1. Save these values directly to your Postman environment under the variables deviceId and hwModel. activator_initial
  • deviceId: Find this value in the Device field.
  • hwModel: Find this value in the Model field.
4. Register the Device (WEDA Core)
Bind your physical hardware credentials to your WEDA Core organization.
Postman Collection: 2-Provisioning&Activation
  1. Node Register: Create a new device under the organization.
  • Method: POST
  • URL: {{apibaseurl}}/orgs/{{org_id}}/devices
  • Payload:
"deviceId": "{{deviceId}}",
"hwModel": "{{hwModel}}",
"deviceName": "{{hwModel}}-{{deviceId}}"
  • Expected result: WEDA Cloud returns 201 and provides the registered device information. At this stage, WEDA Core recognizes the identity of your device. Its status remains Registered until the WEDA Node client daemon is launched and activated on the physical edge.
Postman create device
curl --location --request POST 'https://{domain}/{tenantPath}/{appPath}/api/v1/orgs/{orgId}/devices' \
--data '{
"deviceId": "cc827f50f406",
"hwModel": "ADVANTECH-EDGE",
"deviceName": "ADVANTECH-EDGE-cc827f50f406"
Example Response
"status": "Registered",
Key parameters:
  • deviceId: Must be a MAC address (lowercase letters and numbers only, no symbols).
  • hwModel: Hardware model of the device, for example MIC-710 or ADVANTECH-EDGE.
  • orgId: The organization ID from the previous step — supplied in the URL path, not the request body.
  • status: At this stage, the device is only registered in WEDA Cloud. If WEDA Node is not connected yet, the status remains Registered.
  • deviceName: Optional at registration. If omitted, WEDA Core auto-generates it as {hwModel}-{deviceId} — the Postman request pre-fills {{hwModel}}-{{deviceId}}; you can customize it.
Other APIs in the 2-Provisioning&Activation collection:
  • Node Activation: Get device auth info used for activation (encrypted auth payload/file) (see Appendix).
  • Node List: Get a paginated device list. You should see the newly created device in the list.
  • Node List Under Org: Get the list of devices under the organization.
  • Token Refresh: Get a new access token using the refresh token.
  • Node Deactivate: Deactivate a device by its ID. status: deactivate
  • Node Remove: Delete a device by its ID.
Once the device is activated and syncing, its sensors appear as DataStreams. Those are covered by the 3-Telemetry collection in step 6.
5. Launch WEDA Node and Verify Connection (WEDA Node)
Finalize connecting your device to WEDA Core
Finish provisioning your Advantech edge hardwdare for remote management.
Step 1: Run WEDA Node Activator
step1
  1. Run WEDA Node Activator on the edge device, accessible from the desktop shortcut.
  2. Select Setup WEDA Node
Step 2: Accept License Agreement
step2
Review the End-User License Agreement (EULA). Press Space to scroll and confirm consent.
Step 3: Select Credential Source
step2
You will be prompted to select how this device securely pulls down its central synchronization keys:
Ideal for internet-connected standard devices. It directly links the local WEDA Node to the public WEDA Core service over HTTPS using pre-built master keys bundled with the Activator. Select this option and press Enter.
Expected result: The device will automatically provisioned on the public WEDA Core service on upon starting the Activator.
Option B: Use Local Credential File
For private, offline, or local networks (LAN). If selecting this method, fetch your key file from WEDA Core using the Node Activation API request.
Optional Path
If you need to register by local credential file, follow Appendix: Register by Local Credential File.
Step 4: Confirm Configuration Settings
step9
Verify the displayed installation targets, target endpoints, network interfaces, and parameters, then confirm configuration.
Step 5: Finish Service Connections
The installer pulls the WEDA Node container images, sets up secure network boundaries, and spawns the WEDA Core client services. This takes roughly 2–5 minutes depending on network bandwidth. Do not close the console window or press Ctrl + C, which can interrupt this terminal process. step9
Expected result: Container images downloaded, started, and services running.
Step 6: WEDA Node Installation Complete
afterinstall
Once completed, the Activator launches the live WEDA Node Service Dashboard.
Service Dashboard
Status icons:
  • green — running / connected / registered
  • grey — stopped / unknown
  • red — failed / disconnected
Connection box color:
  • Green border — device connected to WEDA server
  • Red border — REG_FAILED or container not found
  • Grey border — intermediate states
The dashboard auto-refreshes every 5 seconds.
Management Actions
ActionDescription
Update Authentication CredentialsReplace the master key or credential file without reinstalling
Restart ServiceStop and restart all WEDA Node Docker containers
Remove WEDA NodeUninstall containers, volumes, and configuration (type REMOVE to confirm)
Verify WEDA Node Connection from WEDA Core
Postman Collection: 2-Provisioning&Activation -> Node List Under Org
    • Method: GET
    • Description: This request queries the devices under orgId and is used to verify whether the WEDA Node has connected successfully from the Cloud side.
    • Expected result: WEDA Cloud returns 200, and the response includes your deviceId, hwModel, and current status.
    • Connection check: when the node is online and activated, the device status should become Activated. img-nodelistunderorg
Once the WEDA Node client daemon is running and authorized, telemetric updates automatically flow from WEDA Node to WEDA Core.
Postman Collection: 3-Telemetry
Each sensor the device reports becomes one DataStream. Reading a value is two requests: list the device's DataStreams to find the one you want, then query that DataStream's latest value.
Step 1: List the device's DataStreams
  • Data Stream List
    • Method: GET
    • URL: {{apibaseurl}}/orgs/{{org_id}}/devices/{{deviceId}}/data-streams?skipCount=0&maxResultCount=10
    • Description: Returns every DataStream on the device, covering both system status and onboard sensor measurements, with the dataStreamId you need for the next request.
    • Expected result: WEDA Core returns 200 with totalCount and a paged items array. A typical WEDA Node reports around a hundred DataStreams, so raise maxResultCount or page through with skipCount to see them all.
Postman list data streams
Example Response
"totalCount": 102,
"items": [
"dataStreamId": "3a229ace-ba60-0566-bef5-63b3009c29e6",
"dataStreamName": "cpu_context_switches",
"displayName": "CPU Context Switches",
"unitDisplay": null,
"dataType": "long",
"recordToDataLake": true,
"managedBy": "System",
"dataSource": {
"type": "WedaNode",
"sourceEntityId": "9b2ff39e-1245-5b3b-8927-f7fdb0ea7532"
"dataStreamId": "3a229ace-ba5b-6b5f-938f-4ac829368339",
"dataStreamName": "cpu_load_15m",
"displayName": "CPU Load (15m)",
"description": "15 minute load average",
"dataType": "double",
"dataSource": {
"type": "WedaNode",
Key fields:
  • dataStreamId: pass this to the latest-value and historical-value requests.
  • dataType: declares the type of the values this DataStream carries.
  • managedBy: System for streams the device syncs automatically, User for ones you create.
  • dataSource: read-only lineage. For a device sensor, type is WedaNode or WedaSubNode and sourceEntityId is the sensor's resource ID.
  • recordToDataLake: whether values are retained for historical queries.
tip
The request's Tests script stores the result for you: it looks for a DataStream named cpu_usage, falls back to the first item, and writes dataStreamId and dataStreamName into your environment. Run this request once and the next two requests work without any manual copying.
Step 2: Read its latest value
  • Data Stream Latest Value Get
    • Method: GET
    • URL: {{apibaseurl}}/orgs/{{org_id}}/devices/{{deviceId}}/data-streams/{{dataStreamId}}/values/latest
    • Description: Returns the most recent sample for one DataStream, within the system-defined retention period (default 60 minutes).
    • Expected result: WEDA Core returns 200 with the latest sample.
Postman get latest data stream value
curl --location --request GET 'https://{domain}/{tenantPath}/{appPath}/api/v1/orgs/{orgId}/devices/{deviceId}/data-streams/{dataStreamId}/values/latest' \
Example Response
"dataStreamId": "e033b4b3-36e0-4dbc-a6e4-1e77185402f4",
"dataStreamName": "cpu_usage",
"dataObject": {
"timestamp": "2026-06-13T19:27:21.9064265Z",
"value": 52.46
Key parameters:
  • deviceId: The target device for the telemetry query.
  • dataStreamId: Which DataStream to read — captured for you by the Data Stream List request.
  • dataType: Declares the type of dataObject.value.
  • dataObject: The sample itself — timestamp (ISO 8601 UTC) and value.
Other APIs in the 3-Telemetry collection:
Note (Data Stream Historical Values Get):
To change the query time range, open the Scripts tab and set startTime and endTime. Both values use URL-encoded ISO 8601 datetime strings (for example, 2026-03-24T06%3A41%3A04.231Z), not milliseconds.
Default script behavior:
  • startTime: current time minus 1 hour
  • endTime: current time plus 1 minute
Use this method when you need offline deployments or pre-provisioned devices.
  1. Get Local Credential File: Download the credential file (.bin) for the device.
  2. Place the downloaded credential file on the Edge device, or confirm the exact file path before setup.
  3. In WEDA Node Activator, select "Use Local Credential File" and press Enter.
  4. At previous Step 3 (Credential Source), select the authentication method and choose Local Credentials Setup for this scenario:
MethodFileUse When
Auto ProvisionN/AMass deployment - auto provisions many devices
Local Credentials SetupDevice Credential (.bin)Single device with a downloaded credential file
  1. In WEDA Node Activator file picker, select the credential file (.bin) and press Enter.
  2. Verify registration is successful on Edge and Cloud sides (for example, service is connected on Edge and device status becomes Activated on Cloud).
Expected result: WEDA Node is successfully registered and connected using the local credential file.
Next Step
Congratulations! You have successfully onboarded your edge device to the WEDA framework by connecting WEDA Node with WEDA Core, and verified data telemetry. Continue to the next chapter to deploy AI Containers.
Last updated on Aug-2, 2026 | Version 1.1.1
