Upon entering the program editing page, the screen is divided into four primary sections:
Widget Componment: This section offers a variety of component choices, including multimedia, tools, and interactive Widgets.
>Note:
Please note that the interactive component functionality is only available in the Pro version. -
Canvas Block: This section is used to design the program interface. Users can place selected components here and design the layout of the screen, including screen divisions and displays.
Canvas Display Configuration Block: This block can be freely dragged and repositioned. Its features include adding screens, adjusting screen display ratios, showing gridlines, and editing previews.
- Add Screen: You can add screens without limitations to create a multi-screen configuration.
- Screen Display Ratio: You can adjust the display ratio to 25%, 50%, 100%, or choose the option to expand to full screen to fit the page size.
- Show Gridlines: You can display gridlines to assist in aligning components.
- Edit Preview: You can choose whether to display preview images of media within components.
Component Editing Block:
- Select Screen: If multiple screens are added, users can choose the area where components will be placed on each screen.
- Blocks: When multiple blocks are present, users can select each individual block.
- Name: Users can set the name of the program here, and after saving, the name will be displayed in the program list for easy management.
- Background Color: Users can set the background color of the canvas.
- Background Image: If not using a background color, users can add a background image.
- Background Music: Users can choose a music file in WAV or MP3 format. The selected music file will automatically play when the program is running.
- Resolution: Users can set the resolution of the canvas, ideally matching the resolution of the display for optimal visual effects. Additionally, users can adjust between landscape or portrait display modes.
- Coordinates: When using a second screen, users can adjust the coordinates to position the components correctly.
