3.5 Efficiency Indicator Management​
This module configures the indicators to be displayed for each plant object, including both plant (which is also named station)-level and unit-level metrics. The selected indicators will be shown on the Energy Efficiency Comparison, named [EFF Comp] and Correlation Analysis, named [Corr. Analysis].
It supports adding, modifying, and deleting metrics for each object.
Configuration List Display:
Indicator Management List
Add New Configuration:
Add New Indicator Configuration
Key Notes:
  1. Display Format: Configured indicators and their associated objects are displayed in a table format. The object is shown as a slash-separated path: Asset Group Root Node / Station Node. If the root node is a station node, only the station node name is displayed. The "Indicator Name" column lists the selected indicators, categorized by type (Plant or Unit).
  2. Tree Structure Support: Both objects and metrics are displayed in a tree structure and support multi-selection.
  3. Object Tree Structure: The object tree structure has a maximum of two levels. The first level is the asset group root node name, and the second level is the plant node name. If the root node is a plant node, only one level is displayed. Multiple asset groups are listed in parallel.
  4. Indicator Tree Filtering: The indicator tree structure is linked to the object selection. Available metrics are filtered based on the plant type and the mode configured in [Plant Info] (Cooling/Heating/Both). If multiple selected objects belong to different plant types, the indicator tree only displays indicators common to all selected objects (determined by identical metric names).
  5. Overwriting Principle: Indicators can be configured multiple times for the same object, following the overwriting principle (the latest configuration overwrites the previous one).
On this page ...
Is this helpful?
