跳至主要内容
MD5: ccb8d30afd192ad3629133452f66d683
Overview
  • Release Date: 2025/04
  • Support Product: MIC-711-OX4A1
Flash Step
Device Connection
Entering Recovery Mode
  1. Power Off
    • Make sure the MIC-711 is completely shut down.
  2. Connect USB Cable
    • Use a USB Type-A to Micro USB cable to connect the MIC-711 (Micro USB port) to your host PC.
  3. Prepare to Enter Flash Mode
    • Do not power on the device yet.
    • Press and hold the REC button.
    Button
  4. Power On and Reset
    • While still holding the “REC” button, plug in the power cable to turn on the device.
    • Press the “RST” button once.
  5. Hold and Release
    • Keep holding the “REC” button for about 5–10 seconds, then release it.
  6. On Host PC,verify recovery mode by checking if NVIDIA Corp is detected:
    lsusb | grep "NVIDIA Corp"
    Expected output: 0955:7323 NVIDIA Corp
Start flash BSP
Run Command on Host PC
  • Extracted BSP image file
$ cd Desktop/
$ sudo tar -zxvf MIC-711_OrinNX_6.1.0_V1.0.0_SDK.tbz2
  • Switch Directory
$  cd Desktop/MIC-711_OrinNX_6.1.0_V1.0.0_SDK
  • Make sure host pc connects to net cable, and can access network. Run below command to check
$ sudo ./tools/l4t_flash_prerequisites.sh
  • To flash QSPI + NVME SSD:
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" --showlogs --network usb0 p3509-a02+p3767-0000 internal
Note
  • Please not use Vitrual Linux as host because there is easily usb problem.
  • Please not use USB Hub between host PC and MIC device.
  • Please not use account root to execute command.
  • Please attach HDMI monitor to MIC device, until flash process had done and MIC boot in OS
