Release Notes - WEDA v1.0.0
2026 April 08
WEDA (WISE-Edge Developer Architecture) is a modular, open orchestration framework designed to accelerate the development and delivery of edge AI solutions across heterogeneous hardware.
Version 1.0.0 establishes the "Edge-to-Cloud" foundation, focusing on:
  • Seamless Onboarding: Rapid activation via pre-installed utilities.
  • Fleet-wide Orchestration: Unified management of containers and AI models.
  • High-Performance Data: Real-time acquisition for AI inference and training.
Public components updates
This section summarizes the major updates and new features introduced in WEDA v1.0.0, categorized by the core components of the architecture: WEDA Core and WEDA Node. Each component's updates are further detailed by specific features and improvements.
ComponentDetails
WEDA CoreWEDA Core serves as the centralized management engine, providing robust APIs for organizational governance and large-scale fleet operations.
  • Identity & Access Management
    Enterprise Grade Authentication & Security: Supports both JWT token exchange and client credentials flows for secure user and automated service authentication
    Organization Management: Full CRUD operations for hierarchical structures with configurable relationship querying
  • Device Fleet Management
    Lifecycle Management: Comprehensive APIs for creating, updating, deleting, and toggling device activation status
    Device Capabilities: Monitor real-time computing resource availability across all managed devices
    Entity Linking: Mapping tools for linking or unlinking physical hardware to organizational units
    Batch Tasks: Automates large-scale operations and workflows across multiple devices with execution scheduling and result analysis
    Notifications: Centralized management for alert channels (email, webhook) with template support
  • Container Management & Stacks
    Fleet-wide AI Deployment: Execute seamless OTA updates for containerized solutions or AI models across heterogeneous hardware
    Deployment Templates: Configure and version Docker Compose stacks for rapid solution rollout
    Registry Management: Manage credentials for private or public Docker registries
    Configuration Versioning: Safety mechanism allowing for rapid rollbacks and revision comparisons with easy tooling
    Real-Time Service Status: Live tracking of individual stack progress and logs of remote command execution
    Remote Container Lifecycle Management: Control container lifecycles of any device without an on-site visit, complete with audit logs for tracing
  • Data Processing
    Data Transformation: Custom user-defined functions (UDFs) for data normalization and contextualization with scriptable Math Engine (supports JavaScript)
    Rule Engine: Configuration of alert rules, thresholds, and conditions for real-time monitoring
  • Operations Management
    Visualized Transparency: Aggregated system info covering hardware resources and software services in ready dashboards. Simplifying complexity for running complex microservice clusters
    Configurable Metrics: Select key metrics of interest for tracking & collection, ranging from IPMI to container statuses to database health
WEDA NodeWEDA Node is the runtime agent that manages local execution, connectivity, and data processing at the edge. WEDA Sub-Nodes provide open-source templates to support data acquisition over a wide variety of IT/OT protocols.
  • Connectivity & Remote Access
    WEDA Activator for One-Touch Onboarding: Preloaded utility tool with Advantech hardware for rapid activation and environment configuration
    Secure Tunnels: Secure, on-demand remote access sessions (SSH) for troubleshooting and maintenance
    Credential Management: Secure provisioning of encrypted Master Key files and device authentication data
  • IoT Data Acquisition, Modeling & Pre-Processing
    Protocol Templates: Capture data with WEDA Sub-Nodes, via popular fieldbus and IT protocols (Modbus, MQTT). Sub-Nodes provide ready-to-use, open-source containerized templates for custom processing logic and sampling policies
    Advanced Telemetry APIs: High-performance retrieval with pagination and real-time caching for low-latency status updates
    Pre-Built Transformation Functions: Ready-made optimized transform functions for signal processing transforms, filters. Including templates for chunking, smoothing, noise reduction and more
    Git Repository: WEDA Sub-Node Sample Code: Advantech-WISE-Edge/WEDA-Sub-Node
Advantech Container CatalogAdvantech Container Catalog (ACC) is the companion repository of domain solutions and SDKs by our ecosystem partners, domain experts & Advantech together.
Whether you are looking for a ready solution or toolkits to help fulfill your project needs, ACC has a variety of picks for different domains. Each container/SDK has been verified against target Advantech hardware models, so it will work out of the box.
Take a look at the available Containers right here on the Advantech Container Catalog site.
Resources & Support
Learning Resources
Free Trial & Technical Inquiry
